1998 Dodge Caravan no heat
DSHAMLEY
  • 1998 DODGE CARAVAN
  • 4 CYL
  • FWD
  • 153,000 MILES
I need to know were the tempastat
Do you
have the same problem?
Friday, October 1st, 2010 AT 8:08 AM
WRENCHTECH
  • EXPERT
With the engine at full operating temp, locate the 2 heater hoses where they go into the firewall and feel them to see if they are both hot to the touch. If they are too hot to continue to hold.
The temperature is controlled by the use of an air mix door that is operated by an electric motor/actuator. This door can be jammed or the actuator can be inoperative or have stripped plastic gears internally.
Friday, October 1st, 2010 AT 9:25 AM
Recommended Guides
