1998 Dodge Caravan my check engine light keeps coming on
STEVE HEBERT
  • 1998 DODGE CARAVAN
  • 6 CYL
  • FWD
  • 160,000 MILES
The water pump whent so I changed it and the timing belt. Was careful to line up marks.
car runs good then engine light came on misfire on cylinder 1. Replaced cap and rotor and added injector cleaner withing a week light whent out for two months then came back on.
wondering if I can adjust distributor timing on 98 dodge caravan 3.0L
Or
is it a bad injector?
Do you
have the same problem?
Wednesday, July 21st, 2010 AT 12:36 PM
  • EXPERT
Did you replace the plugs and wires too?
Wednesday, July 21st, 2010 AT 10:37 PM
Recommended Guides
