1997 Dodge Caravan Transmission starting in 2nd gear
KEVIN410
  • 1997 DODGE CARAVAN
  • 6 CYL
  • FWD
  • 161,000 MILES
My 97' Dodge Caravan has 161,000 miles and i've had no problems with the transmission since i've owned it. Recently it has been starting in second or third gear. I checked the transmission fluid and it is browing a little bit. When it is really cold outside my van will start in first gear and won't shift out untill the engine completley warms up. Would a tranny flush help solve this problem?
Do you
have the same problem?
Wednesday, January 7th, 2009 AT 12:02 PM
VIPERTEK
Dont bother to flush it. You need to find out what trans codes are present. Not engine codes but trans codes. If there is a speed sensor code they can be replaced for a low cost, however if there is a gear ratio error code along with fault after shift codes there is an internal problem and trans will need to be rebuilt or replaced.
Good luck
Thursday, January 8th, 2009 AT 5:54 PM
Recommended Guides
