1997 Dodge Caravan Not shifting from 1st and speedometer no
RACHAELH
  • 1997 DODGE CARAVAN
  • 6 CYL
  • AWD
  • 233,000 MILES
Hello my van is not shifting from 1st gear my codes say its speed sensors & transmission module. I have replaced both in an output sensors, transmission module and pcm. Nothing has worked and also the PRND3L is always lit up and does not tell me what I am in. I am a woman and trying to do my own autocare and cannot afford to take it and I am hoping you may have some ideas as to what else it could be? Would really like to get it fixed as I am afraid since I am running at about 4000rpm's maybe doing 50 and don't want to blow the motor and be completely without a vehicle. Hope u can help with some possible ideas. Any help will be appreciated!
Do you
have the same problem?
Tuesday, August 26th, 2008 AT 10:11 AM
BMRFIXIT
  • EXPERT
Its wiring harness check TCM for power
Tuesday, August 26th, 2008 AT 12:27 PM
Recommended Guides
