It is located on the Plenum it has a single vacuum line going to it and and electrical connection.
See the diagram below for location. My manual has the same diagram for all 3 engines.
Image (Click to make bigger)
SPONSORED LINKS
Friday, June 13th, 2008 AT 8:40 AM
MANOK
MEMBER
2000 DODGE CARAVAN
6 CYL
FWD
AUTOMATIC
289,000 MILES
Hi bob and ken,
i just want to ask where the MAP sensor is located on my vehicle. Thanks.
Sunday, January 27th, 2019 AT 8:10 AM
(Merged)
MECHANIC
I believe it mounted on the throttle body. If not, let me know and I'll do more checking for you.
(Merged)
OCASIO123
MEMBER
1 POST
1997 DODGE CARAVAN
6 CYL
FWD
AUTOMATIC
100,000 MILES
Can you tell me where thw map sensor is located? And how to replace it?
(Merged)
BMRFIXIT
MECHANIC
What do you have for engine size
right or left side of the intake manifold
SPONSORED LINKS
(Merged)
SOLARBLU
MEMBER
1 POST
1991 DODGE CARAVAN
Electrical problem
1991 Dodge Caravan 4 cyl Front Wheel Drive Automatic
can you tell me where the map sensor and the fuel position sensor is located on a 1991 dodge caravan 2.4L. If possible please send pic or diagram. Thanks.
Sunday, January 27th, 2019 AT 8:11 AM
(Merged)
MECHANIC
The map sensor is on the right side of the firewall and I think you mean throttle position sensor. It is on the throttle body.
