1997 Dodge Caravan Can a 1998 Dodge Caravan transmission f
SHERRIFLI
  • 1997 DODGE CARAVAN
Transmission problem
1997 Dodge Caravan 6 cyl Front Wheel Drive Automatic
that's all I would like to know. Thank you
Do you
have the same problem?
Saturday, May 29th, 2010 AT 11:49 PM
  • EXPERT
Part of the question was ommited. However, I believe you are asking it a 97 and 98 transmission are the same. If that is the case, I have to start by saying we only recommend direct fit parts. When you change years, something always seems to be different with sensors, modules, wiring. However, I would suggest contacting a salvage yard. I personally don't have the cross reference information you need.
Friday, June 4th, 2010 AT 12:54 PM
Recommended Guides
