1996 Dodge Caravan Engine staling and loosing power
LTLDBE
  • 1996 DODGE CARAVAN
  • 6 CYL
  • FWD
  • 249,000 MILES
1996 Grand Caravan SE. While driving van looses power and sometimes stalls after it warms up. Usually does not happen when weather is cold but when weather is warmer it happens much more.
We have had the fuel pump & fuel filter replaced. The coil pack has also been replaced. It is not pulling up any codes. For awhile it was stalling out while turning a corner but since replacing the coil pack it hasn't done it anymore. We are afraid to drive it very far because we can't find out what is wrong - the mechanic states he doesn't know what it could be.
Do you
have the same problem?
Friday, March 13th, 2009 AT 1:48 PM
BMRFIXIT
  • EXPERT
Suspect crank sensor
should have it checked
Friday, March 13th, 2009 AT 7:24 PM
Recommended Guides
