1995 Dodge Caravan missfires
STEVEW78
  • 1995 DODGE CARAVAN
  • 6 CYL
  • 175,000 MILES
My 95 dodge caravan is not able to idle or drive, it constantly missfires, I have changed the plug wires, plugs, fuel filter, and distribitor cap. But the problem still persists.
Do you
have the same problem?
Friday, January 4th, 2008 AT 10:44 AM
BLACKOP555
  • EXPERT
Well first check spark on all cylinders, they should be bright blue and well defined, if they are orange or dull then you should change your coil. If they are all bright and blue.
Then you should perform a fuel pressure test and check for injector pulse if that is all good then I think you should clean out your throttle body, clean out the egr and its ports, and clean your air filter, pcv filter and pcv valve.
Friday, January 4th, 2008 AT 8:43 PM
Recommended Guides
