1995 Dodge Caravan I have the codes 53 and 56 and not make
ECOCASTILLA
  • 1995 DODGE CARAVAN
  • 6 CYL
  • 26,800 MILES
I have problems becuase the transmission not make the changes but only some times and I need to turn off and on and the transmission start to make the changes again, some times the problem is fix for 1 or 2 days but others only for 1 or 2 miles and I need to repeat the operation turn off and on
the mechanical say that I need to reapir the transmission but other guy toll me that is a electrical problem.
I change the 2 transmission sensors and the problem was fix for 2 days only
Thanks!
Do you
have the same problem?
Tuesday, January 6th, 2009 AT 5:14 PM
VIPERTEK
If you have a code that said fault after shift or speed ratio error. Like a 51 52 53 54. You will need to rebuild trans period. Get codes and see if that is what it says
Thursday, January 8th, 2009 AT 6:20 PM
