Firing order
CLESSARY
  • 1999 DODGE CARAVAN
  • 4 CYL
  • 147,000 MILES
My van does not have any fire going to the ignition coil and it hesitated as it was out of fuel before it shut off now it won't start at all. We have checked all the fuses and we have checked the spark plug to check to see if it was firing and used a test light on the plug wire for power that unplugs from the coil. We replaced the coil now I need the firing order.
Do you
have the same problem?
Saturday, November 15th, 2008 AT 7:45 PM
JNOVACK
  • 723 POSTS
The coil pack gets its signal from the power control module (pcm) that gets its signal from the camshaft position sensor and the crankshaft position sensor I would look into checking those sensors if not replace them and if you still don't have spark then you should be able to remove a cover on top of engine were the camshafts are located turn engine over and see if the cams are moving if they are then the pcm needs to be tested. Here is the firing order below. Check out the diagrams (Below). Please let us know what happens.
Saturday, November 15th, 2008 AT 8:26 PM
0HEATHER757
  • 1998 DODGE CARAVAN
  • 6 CYL
  • AWD
  • 192,591 MILES
I have a 1998 dodge caravan. I recently unplugged all the sparks plugs from the distributer cap. I need to know the firing sequence. If you would please assist me in this matter I would greatly appreciate it. Thankyou
Sunday, April 26th, 2020 AT 12:48 PM (Merged)
BMRFIXIT
  • 19,053 POSTS
3.0 engine
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic1_430.jpg
BIGMACK532007
  • 1997 DODGE CARAVAN
  • 6 CYL
  • 145,000 MILES
My van come up with a code for misfire at #4 cylinder. I just replaced the spark plugs about 1000 miles ago. Could it be a bad plug or probaly the wires? Which hole is the #4 cylinder?
Thanks,
MIke
Sunday, April 26th, 2020 AT 12:49 PM (Merged)
  • 31,938 POSTS
Hi there, see pic for firing order 3 litre engine.
https://www.2carpros.com/forum/automotive_pictures/61395_Graphic_153.jpg
mark (mhpautos)
AJROSE90
  • 1996 DODGE CARAVAN
  • 3.0L
  • V6
What is the engine firing order for a 1996 v6 dodge caravan?
HMAC300
  • 48,601 POSTS
Here is the engine firing order in the image below just click to enlarge it.
Cheers
RANDY MORTON
  • 1992 DODGE CARAVAN
I would like to know the spark plug firing order for this topic?
LOSONE
  • 1,616 POSTS
Here is the engine spark plug firing order. 1 2 3 4 5 6 Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Cheers
U0444875
  • 1989 DODGE CARAVAN
1989 Dodge Caravan
I took off the spark plug wires and numbered them and when I put them back on the car will not start. Can you please give me the proper configuration. Thanks.
Sunday, April 26th, 2020 AT 12:50 PM (Merged)
What liter engine? Maybe we can help you out.
U0444875
The engine is a 3 liter V6. We just need a diagram of the spark plug wires. Also the fan belt is torn to shreds. I found a piece of it in the grill, and the fan is not turning. Would that cause the car not to start and is it hard to put on and what tools would you need.
Thanks so much for your help.
Michelle Williams
EMAILBOX1
  • 6 CYL
  • FWD
#5 fuel injector is stopped up how do I fix it. Do you have a firing order diagram for 3.3 v6 dodge caravan.
Friday, June 19th, 2020 AT 1:09 PM (Merged)
  • 31,938 POSTS
The Injector can be bench tested and cleaned or it can be done on car as well, it car is hooked up to a special fuel system cleaner, if done off car all injectors should be cleaned and flow tested. You can also replace it if you wish, see pic for firing order.
Mark (mhpautos)
