1985 Dodge Caravan ENGINE NO POWER SOUNDS LIKE LAWN MOWER E
LESWILK
  • 1985 DODGE CARAVAN
  • 4 CYL
  • 130,000 MILES
SLOWED DOWN ON OFF RAMP WHEN TRINT TO PICK UP SPEED HAD NO POWER
I PULLED THE PLUG WIRES 1 BY 1 ON CYL # 1, 2 THERE WAS NO APARENT CHANGE WHEN I PULLED 3, 4 ENGINE DIED. CHANGED PLUGS, NO HELP CHECKED TO SEE IF SPARK GETTING THRU PLUG YES IT IS. PULLED PLUG 1, AND TO SOUNDS LIKE I HAVE COMPRESSION. DO YOU HAVE ANY SUGGUESTIONS
Do you
have the same problem?
Friday, April 17th, 2009 AT 6:07 AM
  • EXPERT
If you have spark, chances are there is a problem with the fuel injectors or there not getting power. Have you tried a fuel injector cleaner? Also, have you noticed white smoke from the exhaust? Finally, you will need to rent a noid light to check to see if the injectors are getting power. If you find all ok, check fuel pressure. If it is good, check compression.
Let me know what you find.
Wednesday, April 29th, 2009 AT 9:57 PM
Recommended Guides
