1998 Dodge Avenger will not start
PARTIN
  • 1998 DODGE AVENGER
1998 dodge avenger car started for a second then hasn't hit a lick since. Timing belts are good, fuel pump is working. Pulled one spark plug wire and checked to see if getting fire. Did not see any. Car cranks very good. What things could go bad that could cause no spark?
Do you
have the same problem?
Tuesday, March 13th, 2007 AT 7:01 PM
WORDMAN
The Frist thing you should check is the coil>
Sunday, August 5th, 2007 AT 11:13 AM
Recommended Guides
