1998 Dodge Avenger Car does not start on warm days
HUNTER132
  • 1998 DODGE AVENGER
  • 6 CYL
  • FWD
  • 130,000 MILES
Sense I bought this car in the summer, my car did not start unless I drove it everyday. Now that it's winter, it starts up the first time, regardless of how long it has been sitting. Recently up here in the north, we had a warm spell, and I am having the same problem. Car will only start if sitting if it is below 20 degrees, or if I let the fuel pump run a couple times. The fuel pump and the filter were recently replaced. Any thoughts?
Do you
have the same problem?
Monday, March 1st, 2010 AT 9:48 AM
CARADIODOC
  • EXPERT
Sounds like fuel pressure is bleeding off through a leaking fuel injector. This happens on my Caravan with 378,000 miles. The solution has been to turn the ignition switch to "run" and wait a few seconds until the fuel pump turns off, then crank the engine. That couple of seconds is enough time to build fuel pressure in preparation for starting.
Caradiodoc
Tuesday, March 9th, 2010 AT 1:09 PM
Recommended Guides
