Diesel injector
MADDISON98
  • 2006 FORD FIESTA
  • 1.4L
  • 4 CYL
  • TURBO
  • MANUAL
  • 78,000 MILES
Car went to garage with three cylinders running. New diesel injectors was diagnosed and installed. Engineer now says ECU needs testing before car can be started as the not working injector could have damaged the ECU, this is extra to the quote for replacing the injector. If the car is started and the ECU is damaged this could then damaged the new injector. Advice appreciated.
Do you
have the same problem?
Friday, January 27th, 2017 AT 12:21 PM
DOCFIXIT
  • EXPERT
Sounds a little fishy is this the Ford dealer?
Saturday, January 28th, 2017 AT 1:50 PM
Recommended Guides
