My engine stalls at idle?
PATTY789
  • 2001 FORD EXPLORER
  • 4.0L
  • V6
  • 38,000 MILES
My car when I go to stop at a red light it chokes up and then shuts off. I crank it back up it started and it chocked some more. I keep paying the gas it starts going and then it started going like it's fine. Then when I stop again it shut back off!
Thursday, September 26th, 2019 AT 2:53 PM
CJ MEDEVAC
  • 11,004 POSTS
Okay PATTY789
This will sorta guide you to what you have to do, it is really easy to do!
https://www.2carpros.com/articles/stall-at-idle
My wife's is on the top of the engine and has 2 bolts.
Our Escape would idle low, then it got to point it would die when you stopped. Revving + holding brake was only way to keep it running.
Took it to fellow R/C airplane pilot, he doubles as a S.C. State HWY DEPT mechanic.
When I got to his house, he was repairing a tractor. Told him my sob story. Escape was still barely running, I raised the hood.
He said, (and I quote)."It could be the Idle Air Control (IAC)", as he pointed to it, and emphasized it with a sharp rap using the wrench in his hand.
By golly it straightened right up, and ran darn good.
That was a 15/16 Craftsman wrench, box end, kinda a medium rap. LOL!
We removed and cleaned it, it may have gone on being Fine, for a lot longer. Since it was my wife's, I took no chances, with my Well-Being.
YES, I visited parts store and replaced it, figured it had 100,000 miles on it, and constantly was a moving part, replacement of this component, was just preventative maintenance in my eyes.
Hope this helps. Hope I am dead on! Cleaning would be free, and at least Maybe eliminate this factor out of the equation.
You can go on with yours (if it's working well now and replace it later, if you have the same feelings about it as I did.
I looked up a new one at Advance Auto Parts for your vehicle. There was one for about $79.00 if you do need one.
A few pictures of the wife's below, yours is very similar.
Please let us know how this goes.
xiac
The Medic
Thursday, September 26th, 2019 AT 3:32 PM
AMYSWEAT
  • 200,000 MILES
My 2001 ford explorer shut off and now will not start we replaced the maf sensor but still no luck it will run with the sensor off but when you plug it in, it shuts off, checked for leaks and no luck what else could it be? Maybe the iac sensor or tps? Help pls
Friday, October 9th, 2020 AT 12:41 PM (Merged)
  • 52,797 POSTS
Is the check engine light on? If ir is, we need the codes.
Look for vacuum leaks around the pcv. Common for splitting at the elbow causing massive vacuum leak
HEAVENLMC
Engine Performance problem
2001 Ford Explorer Two Wheel Drive Automatic 115251 miles
I have a 2001 Ford Eplorer. Im having problems with it starting in the mornings. It will not stay on unless I keep my foot on the gas. If I take my foot off the truck dies out. If I keep my foot on the gas for about 15 min it will finally stay on for me to get it in gear. The rest of the day its fine.
  • 108,170 POSTS
Has the check engine light come on? Have you checked the idle air control valve? Has the EGR been checked as well as checking for vacuum leaks?
HEAVENLMC
No. I kept being told it was fuel pump. Ill have that checked. Thank you
  • 108,170 POSTS
If you need directions to check the pump on your own, let me know.
ROBBIE945
  • 6 CYL
  • 4WD
  • 149,275 MILES
My vehicle will not run at idle, I have to feed it fuel. Also when I come to a stop sign it will stop running. If I come to a corner to turn and the idle drops it will stall out.
MERLIN2021
  • 17,250 POSTS
If the check engine light is on, read the codes, read em anyway, sometimes there is freeze frame data that will tell you what specifically happened, if nothing found check the Idle air control valve, it's bolted to the throttle body. Get a can of spray gumout, spray the vac lines and maniflod area, when the idle changes, youve found the leak! You want the engine running and spray on the outside but do direct the stream onto the hoses, if it is a vacuum leak, the engine idle will change speed, then you have detected a leak, repair the vacuum leak and see how it runs!
ROBBIE945
Thanks Merlin, thats where the problem is, there are no codes showing up as a hard fault code.
MERLIN2021
  • 17,250 POSTS
OK, let us know how it goes.
ROBBIE945
Hi Merlin just wanted to let you know that I found the problem with my 2001 explorer. I checked for a vacuum leak like you suggested and found none. I then went a little deeper and found the idle spped control on top of the throttle body was stuck. I removed this and cleaned it and it works fine now. Thanks anyway.
MERLIN2021
  • 17,250 POSTS
When the IAC sticks, it's a vacuum leak!
LYNDEL MOORE
  • 19 POSTS
  • 2000 FORD EXPLORER
  • 4.0L
  • 6 CYL
  • 4WD
  • 223,699 MILES
Since it has gotten warmer out after driving a distance tries to shut off when at an idle and when air is on also when driving.
  • 108,170 POSTS
Has the check engine light stayed on when the engine was running? If it has, then you should have the computer scanned for diagnostic trouble codes. Here is a quick video that shows how it's done:
https://youtu.be/YV3TRZwer8k
I realize most people don't own a scanner, but often times a auto parts store will do it free of charge. So if the light stays on, have that done.
I have to be honest. What you described sounds like an issue with what is called an idle air control valve (IAC). The IAC is what is responsible for maintaining engine idle speed. Also, when you turn the AC on, it should react by increasing the idle speed to accommodate the added load.
Please understand I am mentioning the IAC based on the symptoms. You can try to service it. It is located on the throttle body. Take a look through this link:
https://www.2carpros.com/articles/idle-air-control-valve-service
If you find it is bad, here is a link that shows in general how one is replaced:
https://www.2carpros.com/articles/how-to-replace-an-idle-speed-control-motor-iac
___________________________________________________
Here are the directions for replacement specific to your vehicle. The attached pictures correlate with the directions.
2000 Ford Truck Explorer 4WD V6-4.0L VIN E
Procedures
Vehicle Powertrain Management Fuel Delivery and Air Induction Idle Speed/Throttle Actuator - Electronic Service and Repair Procedures
PROCEDURES
REMOVAL
NOTE: The 5.0L is shown, the 4.0L SOHC and the 4.0L (push rod) engines are similar.
1. Disconnect the battery ground cable. For additional information, refer to Battery.
pic 1
2. Remove the accelerator control snow shield.
pic 2
3. Disconnect the idle air control (IAC) valve electrical connector.
pic 3
4. Remove the IAC valve and discard the gasket.
INSTALLATION
1. To install, reverse the removal procedure.
NOTE: Install a new IAC valve gasket.
Let me know if this helps. Also, if you find there are diagnostic trouble codes, let me know what they are. We'll work through it together.
FOUSTSANDRA
  • 6 CYL
  • 4WD
  • 175 MILES
2001 ford explorer shakes and wants to stall when sittin still drives fine on road
WRENCHTECH
  • 20,757 POSTS
You may have a bad IAC ( idle air control) but try cleaning the throttle body first. Remove the intake snorkel, have someone hold the throttle wide open for you and scrub the back side of the throttle plate and surrounding bore with an old tooth brush and some carb cleaner. Be sure to spray some into the small holes next to the throttle plate. That should help stabilize the idle. If it still has a problem, replace the IAC.
CARDFAN
2001 Ford Explorer 6 cyl Automatic
When you start the car, it won't stay running unless you keep pressing the gas. Sometimes to start it you have to press the gas just to get it started.
Friday, October 9th, 2020 AT 12:42 PM (Merged)
LEGITIMATE007
  • 5,121 POSTS
If you dont have an engine light on, I would check the fuel pressure regulator and the idle air control valve. Let me know what you find
LEGITIMATE007
  • 5,121 POSTS
https://www.2carpros.com/car_repair_video/test_fuel_injection_pressure.htm
