Dash or ignition issue, not sure which
CSAUNDERS316
  • 1984 FORD F-150
  • 4WD
The dash lights do not work at all, speedometer gauge is only gauge that comes on. No wipers, no turn signals. Wipers and gas gauge will come on only if you hold ignition in a certain spot just before starting the truck to clear windshield or check amount of gas, Does not work while running.
Not sure if it is an electrical/fuse issue or an ignition/wiring issue.
No idea where to start.
Do you
have the same problem?
Wednesday, September 30th, 2015 AT 10:35 AM
CAR-MAN145
  • EXPERT
I would start with the ignition switch
Thursday, October 1st, 2015 AT 1:02 AM
Recommended Guides
