2002 Daihatsu Terios oil consumption
ARTHUR REDDICK
  • 2002 DAIHATSU TERIOS
Engine Mechanical problem
2002 Daihatsu Terios 4 cyl Four Wheel Drive 165000 miles
inconsistent oil burn or at lest indication on the dip stick
on one run say 1000kms will use very little but on same return trip will use a full sump of oil
Do you
have the same problem?
Monday, July 20th, 2009 AT 1:21 AM
  • EXPERT
Hi there,
What weight of oil are you using and is it synt or mineral. Are you constantly topping up and not doing the service oil change?
Mark (mhpautos)
Monday, July 20th, 2009 AT 1:29 AM
Recommended Guides
