1992 Daihatsu Charade help
RICOMAMBO
  • 1992 DAIHATSU CHARADE
Engine Mechanical problem
1992 Daihatsu Charade Front Wheel Drive Manual 39889 miles
hello
i have a 92 model daihatsu charde 3 cylinder and the problem is there is a whtie smoke coming out in my exsaust there is also a little oil wet in the tip of my exsaust I already brought it to a mechanic replaced valve seals, valve, piston ring, sparkplug and still white smoke is coming out my mechanic said that my lining is still ok I also notice my sparkplug is wet I think its oil. I've spend lots of money just by going to the mechanic to fix the problem but still no good result happen the problem is still there. Can you help me? Pls tnx very much
Do you
have the same problem?
Sunday, July 19th, 2009 AT 7:54 PM
DAVE H
Have a cylinder compression test !
Thursday, July 30th, 2009 AT 5:41 AM
Recommended Guides
