Cranks will not start
WILDBILL5150
  • 1992 NISSAN MAXIMA
  • 3.0L
  • V6
  • FWD
  • 150,000 MILES
Engine cranks will not start. Security light on dash flashes at all times except when key is in start mode. Tried locking and unlocking doors how or what is causing my car not to start?
Do you
have the same problem?
Saturday, January 28th, 2017 AT 11:48 PM
STEVE W.
  • EXPERT
Security light flashing means the system is not recognizing the key you are using. Has the battery been disconnected before this? You can try a security reset but it may not help if it is a mechanical failure of the key reading system. For that you would need to use a scan tool and determine what is actually the problem.
https://www.2carpros.com/articles/how-to-reset-a-security-system
Sunday, January 29th, 2017 AT 4:20 AM
Recommended Guides
