Cranks wont start
BRIAN D RUMSEY
  • 13 POSTS
No. There are no codes in the computer. I have checked all fuses everything. New cam sensors new crank sensor new computer.
Tuesday, September 13th, 2016 AT 5:16 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,870 POSTS
Does the engine have compression?
here are some guides that will help you
and
Let us know what you find so it will help others
Wednesday, September 14th, 2016 AT 5:21 PM
BRIAN D RUMSEY
  • 13 POSTS
Ok compression is good. And I am getting about 280 to 300 rpm while engine is turning over. But I am still getting no spark from any of the coils
Saturday, September 17th, 2016 AT 9:40 AM
KEN L
  • 42,870 POSTS
It looks like its time to do a pin to pin check of the wring harness, must be a shorted/broken wiring somewhere plus you can check the power and grounds, here is a guide that will help you
Please let us know what you find so it will help others.
Best, Ken
Saturday, September 17th, 2016 AT 6:48 PM
BUDDIE95
  • 5 POSTS
Hello everyone, I realise this is an oldish post. But, I have a 2004 3.5liter V6 petrol 5 speed rodeo. I have been having an issue where the engine will crank but not start. The problem was intermittent at first but became progressively worse until the engine would not starter all. I have now worked out that the problem is either the fuel pump or the fuel pump relay. I swapped the fuel pump relay with the horn relay and the engine started. Just have to see if the problem occurs again now to test the pump. And yes the horn still works. Hope this helps.
Sunday, January 31st, 2021 AT 4:47 AM
KEN L
  • 42,870 POSTS
This sounds like a fuel pump or the crankshaft angle sensor has gone out. When you turn the key to the on position without cranking the engine over can you hear the fuel pump run in the tank for 5 seconds?
Sunday, January 31st, 2021 AT 11:25 AM
BUDDIE95
  • 5 POSTS
Hi Ken,
No can’t hear the pump. It did the same thing yesterday so I shorted out the two large terminals for the relay and there was no difference. Also when cranking there is no fuel pressure at the valve on the left side fuel rail. I will be pulling the old pump out tomorrow and replacing with new one.
Tuesday, February 2nd, 2021 AT 4:24 AM
BUDDIE95
  • 5 POSTS
On another note, can anyone explain why I get very bad fuel economy from this engine? Roughly 6km per 1 liter. 2004 Holden Rodeo with 3.5 liter V6 petrol with 5 speed manual box.
Tuesday, February 2nd, 2021 AT 4:27 AM
KEN L
  • 42,870 POSTS
You will need to start a new question for the Holden, if you have power to the pump but no pressure you will need to change the pump out here are the instructions. Check out the diagrams (below). Let us know what happens and please upload pictures or videos of the problem.
Wednesday, February 3rd, 2021 AT 11:01 AM
BUDDIE95
  • 5 POSTS
Thanks Ken. I have replaced the fuel pump and the engine starts with no problem at all. By the way, I didn't take the tank out, I just undid a couple of the nuts and bolts holding the tray on and then jacked up the tray which gave me ample room to remove and replace the pump assembly.
Wednesday, February 17th, 2021 AT 4:35 AM
