Crank shafts sensor light comes on and blinkers don't work. When light isn't on blinkers work.
JIMMYROLINJR
  • 1997 OLDSMOBILE CUTLASS
  • 3.1L
  • 6 CYL
  • FWD
  • 170,000 MILES
Crank shafts sensor light comes on and blinkers stop working but when lights off they work.
Do you
have the same problem?
Friday, June 19th, 2015 AT 7:25 PM
CARADIODOC
  • EXPERT
There's no such thing as a "crankshaft position sensor light". Are you referring to the Check Engine light? If not, you're going to have to describe it's color and shape of the symbol.
This sounds like an intermittent connection in the 12 volt feed to the signal circuit, but that also feeds other things. Have you noticed if other things stop working at the same time, like the radio, wipers, or heater fan?
Friday, June 19th, 2015 AT 7:59 PM
Recommended Guides
