Where is the ignition module - I need the wiring diagrams as well?
BOWDOC13
  • 1995 FORD RANGER
  • 125,000 MILES
Online manuals show the module on the intake manifold but its not there?
Sunday, January 15th, 2012 AT 12:43 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,833 POSTS
On the manuals I look at they say there is no ignition module for this car because it is integrated into the PCM. Here are the wiring diagrams so you can see for yourself (below) I have the PCM location for you if you want to try a used one. What problem are you having? Check out the diagrams (Below). Please let us know what happens.
Friday, September 8th, 2017 AT 11:43 AM
RES0KKW
Its like its not getting any fire at all. But after an hour it starts up everytime. Seems to be doing it more often now that its wamrer weather. It never dies driving down the road it only happens after turning it off.
We now know when it doesnt start if you put gas or starting fluid in the carb it starts up. So could it be the fuel relay or whateever its called.
Friday, September 8th, 2017 AT 11:44 AM (Merged)
DOCFIXIT
  • 18,828 POSTS
Either relay or fuel pump can you hear pump run?
RES0KKW
Yes you can hear the pump.
Where is the relay?
DOCFIXIT
  • 18,828 POSTS
If pump runs then relay is good need to check fuel pressure when it won't start. Should be 35-45 psi
JUSTIN RUDOLPH
  • 1995 FORD RANGER
  • 4.0L
  • V6
  • 175,000 MILES
I cannot find the ignition control module on a 95 Ford ranger 4.0 any ideas where it's at
HMAC300
  • 48,601 POSTS
That's because it's in the pcm
WANDA BOSLEY
  • 1996 FORD RANGER
Electrical problem
1996 Ford Ranger 4 cyl
where is the ignition module located on a 1996 ford ranger pickup 4.0 engine
BLUELIGHTNIN6
  • 16,542 POSTS
Your vehicle uses the GEM (generic electronic module) and it is located behind the center of the dash.
WANDA BOSLEY
I have a 1997 chevy pickup s10 I idles perfect put when you accelerate quickly it splutters and misses what it the problem
DOCFIXIT
  • 18,828 POSTS
Does not have one all is controled through PCM. What is problem?
BLUELIGHTNIN6
  • 16,542 POSTS
If you have an S10 then why you asking about a Ford ranger?
WANDA BOSLEY
Because I have both vehicles and I am not real good on a computer and I am trying to get answers to both before I lose this web site whichever one I can get running is the one I will drive Thanks for your information I really appreciate the help I hope this does not sound smart because it is not meant to be
BLUELIGHTNIN6
  • 16,542 POSTS
No problem, just making sure you typed the correct vehicle in. For the Ford, like Doc said it does not have a separate ignition module, it uses the powertrain control module (PCM) and also has Fords generic electric module (GEM).
For the Chevy issue, is the check engine light on in the dash panel? Could be as simple as a bad mass airflow (MAF) sensor, but if you have engine light on then you should take it to local auto part store and ask them to retrieve your vehicle's check engine trouble codes. That will help pinpoint the issue. You can post the code(s) you retrieve here and I will follow up.
WANDA BOSLEY
I talked to you earlier about the 1997 chevy s10 the code showing up is 1336 we have replaced map senser crank senser cam senser IAC valve throttle position senser oxygen senser ignition module coil packs wires and plugs checked fuel pressure compressio timing chain we have pulled the head to make sure no valves were burnt It is about to cause me to go BANKRUPT I really like the pickup and would like to get it running Thanks for your help IT IS GREATLY A PPRECIATED and I can't believe I found someone willing to give me free help
BLUELIGHTNIN6
  • 16,542 POSTS
1336 means you need to "teach" the computer to read the crank sensor correctly. You will need a scan tool for this.
Install scan tool
vehicle in Park or Neutral
engine coolant temp. At 158 degrees F
engage parking brake
block vehicle drive wheels
turn all accessories Off
enable the crankshaft position system variation learning procedure with the scan tool
raise engine speed to 3920 RPM and release throttle as soon as the engine cuts out
The scan tool should indicate that the crankshaft position system variation has been performed
Afterwards, use the scan tool and select DTC, CLEAR INFO. Then start and warm engine to normal operating temp. Select DTC, SPECIFIC, then enter DTC P1336. Operate vehicle. Scan tool will then indicate wether the test passed.
DOCFIXIT
  • 18,828 POSTS
Vehicle does not have ICM all is controled by PCM. What is problem?
JR42717
  • 7 POSTS
  • 1994 FORD RANGER
  • 6 CYL
  • 156,200 MILES
Engine Mechanical problem
1994 Ford Ranger 6 cyl Two Wheel Drive Automatic 156200 miles
i cant find the ignition control module, ive tried calling the ford dealership and parts store.
Pick your liter engine:3.0L or 4.0L
1994 Ford Truck Ranger 2WD V6-182 3.0L
Component Locations
https://www.2carpros.com/forum/automotive_pictures/12900_icm_6.jpg
The Ignition Control Module (ICM) is located at the LH front of engine compartment, on upper radiator support.
1994 Ford Truck Ranger 2WD V6-245 4.0L
Component Locations
https://www.2carpros.com/forum/automotive_pictures/12900_icm1_1.jpg
The Ignition Control Module (ICM) is located at the LH front corner of engine compartment, mounted on upper radiator support.
CHRIS22
  • 1994 FORD RANGER
1994 Ford Ranger 4 cyl Two Wheel Drive Manual
no fuel no spark already changed ignition control module and the crank sensor what else can it be
Monday, September 7th, 2020 AT 2:00 PM (Merged)
