Cold started. Car fired then engine died. Will turn over but not start.
MWIAN
  • 1996 FORD ESCORT
  • 1.8L
  • 4 CYL
  • FWD
  • MANUAL
  • 100,000 MILES
I got in the car in the morning to drive. Started the engine. Engine fired up but then died.
The car has never died after starting. I went to restart, but the engine just turns over.
I took a spark plug out. There is spark. I can smell fuel on the plug.
My first thought when the car died was that the cam belt just broke, but I opened the cover, cam belt is still ok.
I have not done anything to the engine in the last 6 months, though I did change a wheel bearing yesterday. Obviously that's not engine related.
I have looked to see if others have had the same problem. There is mention of cleaning the crank sensor, but I can't see where that is.
Do you
have the same problem?
Sunday, December 1st, 2013 AT 3:26 AM
HMAC300
  • EXPERT
Scan for codes and check fuelpressure first.
Sunday, December 1st, 2013 AT 6:00 AM
Recommended Guides
