2005 Chrysler Town and Country Power Door Locks
RACORBY
  • 2005 CHRYSLER TOWN AND COUNTRY
Electrical problem
2005 Chrysler Town and Country 6 cyl 80000 miles
My door locks occasionally stop working via the remote and the internal door switch. I read once online to remove one of the fuses under the hood for 45 seconds and then put it back in to fix the problem. Amazingly, this works.
However, the original problem comes back in a week or two. Removing the fuse fixes it. Is there a more permanent solution?
Do you
have the same problem?
Friday, July 24th, 2009 AT 1:03 PM
BMRFIXIT
  • EXPERT
Check relays and suspect BCM module
Friday, July 24th, 2009 AT 11:02 PM
Recommended Guides
