2005 Chrysler Town and Country fluid leak
FR
  • 2005 CHRYSLER TOWN AND COUNTRY
2005 Chrysler Town and Country 6 cyl Front Wheel Drive Automatic
Red fluid under front left side of van, however fluid levels are full. Where could leak be coming from?
Do you
have the same problem?
Friday, January 2nd, 2009 AT 1:53 PM
ZACKMAN
Red fluid is your transmission fluid. With the engine running, move the shifter through the gear, holding 5 seconds per gear, and then move the shifter back to park. With the engine running, remove transmission dipstick, wipe it clean, re-insert it completely and remove to check the fluid level.
It is probably coming from one of the transmission hoses from the radiator.
Tuesday, January 6th, 2009 AT 12:27 AM
Recommended Guides
