25 amp breaker on the driver
LMONTERO
  • 2005 CHRYSLER TOWN AND COUNTRY
6 cyl Two Wheel Drive Automatic
where do I locate the 25 amp breaker on the driver side window?
Do you
have the same problem?
Saturday, September 26th, 2009 AT 9:12 AM
BMRFIXIT
  • EXPERT
The window circuit breaker is located in the driver side kick panel. Here is a guide to help you test it.
Here are the fuse panel locations and identifications as well. Check out the window wiring diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Cheers
Sunday, September 27th, 2009 AT 2:14 PM
Recommended Guides
