2002 Chrysler Town and Country Starts and dies
DRIFTER51
  • 2002 CHRYSLER TOWN AND COUNTRY
  • 6 CYL
  • 118,000 MILES
I went to start the van and it started fine and ran for 5 seconds and died. This repeated 4 times. I cleaned the battery cables and now it doesn't turn over. The lights do not dim when the switch is turned to start engine. This happened a couple of weeks ago, and I put a trickle charge on for a few minutes and it started and ran fine. I brought it in to have it checked out and everything seemed to check out fine. Drove it home and parked it for a couple of weeks. Then I had the current problem of starting and dying and now nothing.
Do you
have the same problem?
Tuesday, September 7th, 2010 AT 8:16 PM
2CEXPT
Hi drifter51, Welcome to 2carpros and TY for the donation
If its cranking over and will not start, do below to determine if its fuel or spark problem and get back with me
Monday, September 13th, 2010 AT 11:30 AM
