Camshaft sensor?
SLONG391
  • 2004 CHRYSLER TOWN AND COUNTRY
  • 3.8L
  • V6
  • 94,000 MILES
Spun rod bearing. Replace crank and bearings, oil pump and timing chain and gears. All were aftermarket parts. Started car and CEL code p0344 then code p0016. Replace both cam and crank sensors and code p0016 stopped setting but the p0344 always is there. Car will long crank sometimes, Using the alldata chart for this code tried to follow the yes and no questions but don't have a DRB scan tool or a lab scope but I did check the 5 volt ref. And it was there. Check the sensor ground and it was good. Checked the cam signal wire voltage Koeo it was 4.98 volts. Also ohm all three cam sensor wires individually from sensor connector to pcm connector and all ohm out at 0.5 ohm. Did try wiggling the harness, checking connectors. Nothing found. This car is driving me crazy.
Tuesday, September 30th, 2014 AT 6:18 PM
CARADIODOC
  • 33,738 POSTS
A lot of independent shops bought Chrysler's DRB3 scanner because with an extra plug-in card, it will do emissions-related stuff on any brand of car sold in the U.S, '96 and newer. I have one for my personal vehicles. If you can't find one at a local shop, almost all aftermarket scanners will do the same things within a few years. Every shop will have something that will cover almost everything on a 2004 model.
What you want to look at is if the cam sensor is listed as "no" or "present", or whatever similar terminology they use. The most common cause of loss of signal is failure to install the paper spacer when installing a used sensor. New ones will have a thick paper spacer stuck on the end to set the critical air gap. That spacer slides off the first time the engine is cranked, but it's job is done by then. Aftermarket sensors can have a thin plastic rib molded on the end to set that gap. When those sensors are reinstalled, you're supposed to cut the remaining part of the rib off, then use a new paper spacer.
If there was no spacer and the sensor was pushed all the way in, it could be broken from hitting the sprocket.
Here is the sensor location. Check out the diagrams (Below). Please let us know what you find.
Tuesday, September 30th, 2014 AT 10:27 PM
SLONG391
Thanks for the reply but I figured it out. The vehicle is a 2004 but the motor must be a 2005 because the cam sprocket does match the one from 2004. The 2005 has an extra notch that the 2004 doesn't have. I really didn't notice the difference when rebuilding the engine. Going to remove the timing cover and put the old cam sprocket back on
Wednesday, October 1st, 2014 AT 8:57 AM
CARADIODOC
  • 33,738 POSTS
Dandy. Holler back to let me know when it's running without setting a code.
Wednesday, October 1st, 2014 AT 9:46 PM
COURPAY
  • 2002 CHRYSLER TOWN AND COUNTRY
  • 158,000 MILES
I need to replace both my crankshaft sensor and my camshaft sensor on the 3.3 liter Town and Country, but I cannot locate them. Are there any diagrams available anywhere on the web? I have been searching all day. The only directions I get are general locations. Please help.
Monday, May 18th, 2020 AT 2:11 PM (Merged)
CARADIODOC
  • 33,738 POSTS
Here are two guides that will give you an idea of what you are in for when doing the job
and
https://www.2carpros.com/articles/camshaft-angle-sensor-replacement
The crankshaft position sensor is on the transmission bell housing near the firewall and rear cylinder head. It requires a thick paper spacer to set the critical air gap. Many aftermarket sensors have a thin plastic rib molded on instead of that spacer.
The camshaft position sensor is around the thermostat housing here are diagrams to show you the location of both sensors
Cheers
COURPAY
Well I am getting two engine codes a P1391 and a P0601. Some trips the car runs fine and then on the very trip it stalls out, or doesn't want to keep running at all. I have replaced all the plugs and a starter recently. If I accelerate, it sometimes sputters and wants to cut out. But then continues on, sometimes it sputters and does stall out. So I figured one or both of these sensors may be the problem.
CARADIODOC
  • 33,738 POSTS
There's a much better way of figuring out if a sensor is failing but it requires a scanner that can display live data. I use the Chrysler DRB3 but there are a lot of good aftermarket scanners out there that do almost as much.
Here is a guide that can show you how to scan your car
The two sensors are listed on the DRB3 as "no" or "present" to show whether those signals are being received. That makes real quick work out of a no-start condition but when you have an intermittent loss of one of the signals, there is a record feature that is used during a test drive. You press the "record" button when the problem occurs, then you can play back the data stream later to see what happened. Since that data travels through the scanner's memory, the recording actually starts a couple of seconds before you pressed the button.
The next best thing is those fault codes but the P1391 suggests the Engine Computer doesn't know which signal is being lost. Whenever it sees one signal, it knows the other one should be there too. Connector and wiring problems account for about half of the fault codes, and a defective sensor about the other half. The two sensors share a common feed wire and a common ground wire. At that point the engine would stall and not suddenly start up again. Once the short is gone, you have to turn the ignition switch off, then restart the engine to reset the 8.0 volt supply.
There are other ways for sensors to fail that do not cause the power supply to shut down. One thing that bit me was not using that paper spacer on the end of the crankshaft position sensor. After replacing a dozen transmissions, I felt confident in setting the air gap by feel, but on the 13th transmission job, that one developed an intermittent stalling problem two weeks later. In response to the intermittent loss of crank signal fault code, another mechanic replaced that sensor and solved the stalling, but I have to assume it was because I didn't use that spacer.
If you're going to guess at a solution, start with the crankshaft position sensor. Never replace two or more things at once. If you end up with a no-start condition due to some mistake or a defective new part, you want as few variables as possible to contend with. Camshaft position sensors are a common problem on Neons and Intrepids, but I've never replaced one on a 3.3L / 3.8L.
COURPAY
Thanks for all your help and advise Caradiodoc, I really appreciate it, I went out and got the Crankshaft sensor, but am still having a bear of a time trying to locate where it goes. You say its on the bell housing near the firewall. So is this something I need to get to from under the Van? Can I get to it from the front of the van? What is it by? Is it facing the firewall? Is it near the starter? Left? Right? Is it facing the radiator? I feel this is like trying to find whats inside Al Capones vault. If it is facing the firewall, do I need to remove the windshield washer mechanism to get to it? I am seeing many sensores, but not this one. Why is there not a clear picture anywhere on the web for this? I appreciate your help.
Remember I am not a mechanic by trade so as I slide under the van give me direction like where is is in relationship to the say oil pan or transmission pan? I have seen posts saying you can see it if you remove the battery tray, I have seen other posts saying you can see it if you remove the air filter attachments and follow the 1/2 inch wire harness South? These are on opposite sides of my car anyways?
CARADIODOC
  • 33,738 POSTS
It's on the back side near where the steering column comes out of the firewall and goes into the rack and pinion steering gear. If you look at where the starter attaches on the front, look an inch or two towards the driver's side on the bell housing, then find the matching point on the back side. Here's a photo of the part from rockauto. Com.
I left the dealership in '99, and I see this is a different design sensor than what I'm familiar with. There's no way to use that paper spacer I mentioned with this one. I have another Chrysler expert stopping over in a few minutes. I'll ask him if they moved the location of this sensor. I'll also keep trying to locate a better picture of its location.
JABELB
  • V8
  • AWD
  • 106,109 MILES
Ok, my van is dying and when it does it is very gassy. It dies when I go into reverse or put into drive, I have had it dye at stop signs. The check engine light is not on. I had in the shop about a month ago because it died and I couldn't get it started so I had it towed. They hooked up to computer and didn't show anything wrong. Said they put some gas in it and is started, it was low on gas but I couldn't believe they said it was empty, anyways, so we put in both oxgyen sensors, didn't help, (someone said that what was wrong) put new spark plugs and wires on today, still didn't help. When I'm driving down the road sometimes it will start chugging like its not getting any gas. It has a plastic gas tank and I did buy a fuel filter but have not put that on because my husband doesn't think thats what it is. Some people say it is the throttle position sensor, some say cam position sensor. Do you have any clues. We know where the cam sensor is located but not sure where the throttle sensor is at, any help with that would be appreciated also. Thanks
  • 31,938 POSTS
Hi there,
If any of these sensors are faulty you will get a code set. I would be getting the fuel pressure and flow checked and replace that fuel filter as well, start here.
Mark (mhpautos)
CWGLINDN
My 2002 had an engine replaced last year, and just started having issues like it is over heating and will die at stop signs and pushign the gas pedal seems to slow the car down and accelerate the problem. I found that the thermostat was in backward, but didn't solve the problem, I pulled the waterpump, but no issues. On hot days over 100 it is bad. I have to wait 45-1 hour to let it cool. Even if I can get it started, cold, it still must be started without pushing the gas pedal and cranking the engine 5-6 times going all the way off then to start. My ac blower is going too! AARGG. ALSO the temp gauge never goes above half way? Maybe the belts are on wrong. Anyone have a diagram.
PAYTON55
  • 1999 CHRYSLER TOWN AND COUNTRY
  • 6 CYL
  • 180,000 MILES
Were is it located
BLUELIGHTNIN6
  • 16,542 POSTS
Depends on engine size? 3.0L its in the distributor. On the 3.3L and 3.8L it's on front of engine. Post engine size and I can give diagram of it.
PAYTON55
3.3 liter engine
BLUELIGHTNIN6
  • 16,542 POSTS
https://www.2carpros.com/forum/automotive_pictures/261618_Graphic_478.jpg
CHARLIER78
  • 2005 CHRYSLER TOWN AND COUNTRY
  • 112,000 MILES
The car won't start it wants to but it just won't I have checked the fuel pressure I'm getting 52 PSI I'm not sure the amount of pressure that it should have also I don't have a port on the rail I have to use it at the quick disconnect and the quick disconnect doesn't fit securely with the t valve that comes with the test kit and leaks a little during testing. I have replaced the TP sensor the camshaft positioning sensor the idle air control valve the map sensor and the coil pack
Monday, May 18th, 2020 AT 2:12 PM (Merged)
CARADIODOC
  • 33,738 POSTS
You need some punctuation in that really huge sentence, otherwise it can be read at least three different way. Have you checked for diagnostic fault codes? Have you checked for spark? 52 pounds of fuel pressure is plenty but that doesn't mean the injectors are firing. Which engine do you have?
CHARLIER78
The engine is 3.8 v6, I have checked code's that is why I replaced all the other parts
CARADIODOC
  • 33,738 POSTS
Fault codes never say to replace parts. They only indicate the circuit or system that needs further diagnosis. What were the exact code numbers?
Have you checked for spark? If there is none, check if the automatic shutdown (ASD) relay is turning on during engine cranking. The easiest way to do that is to measure the voltage on the dark green / orange wire at the coil pack or any injector. (My newest service manual is for an '02. If your wire colors are different, it will be the same color at all those places). You should see 12 volts for one second after turning on the ignition switch, then it should come back during cranking.
