2004 Chrysler Sebring oil light flickers at stop
JOHNVTOMEY
  • 2004 CHRYSLER SEBRING
  • 6 CYL
  • FWD
  • 70,000 MILES
I'm trying to help a friend out with this problem. I know the 2.7l has this problem. He says the oil light flickers at a stop but goes away as he starts to move. He does notice a minor leak near the oil pan. He just went to using mobil 1 10w30. But this symptom was happening before the change to mobil 1. Just out of curiosity I hooked the car up to a diagnostic tool and got the following code even though the check engine light was not present at the time but did come on 2 days prior but went away. P0137 o2 sensor cicuit low volts(bank 1 sensor 2). Sounds like separate issue but I may be wrong. I've read about an oil sending sensor being bad or something? I would appreciate any suggestions. He's being stationed in Texas and is a littled worried about driving the car down. Thanks for the help.
Do you
have the same problem?
Friday, January 30th, 2009 AT 9:34 PM
BMRFIXIT
  • EXPERT
Replace oil pressure switch
Saturday, January 31st, 2009 AT 5:56 AM
Recommended Guides
