How do I fix the passenger seat flip release lever that allows to fold forward at top of seat?
SEBRING1
  • 2008 CHRYSLER SEBRING
  • 91,000 MILES
The flip the release lever up on the top seat release doesn't work (Top of seat left(driver side)of the head rest)on our convertable, the lower flip release lever works fine. The upper lever pulls up but doesn't make the seat go farward to let someone in the back seat, the lower lever works fine.
Monday, September 24th, 2012 AT 6:03 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,798 POSTS
It sounds like you have a control rod that was fallen off. You will need to remove the seat and then flip it over to inspect. There could be a small rod that has come disconnected that will need to be reattached. Here are diagrams below to help you see what I am talking about. Check out the diagrams (Below) Please let us know if you need anything else to get the problem fixed.
Wednesday, November 23rd, 2016 AT 12:32 PM
RMESSNICK
  • 2004 CHRYSLER SEBRING
  • 138,000 MILES
The seat is stuck in a forward position and the lever does not work to allow the seat to move forward or backward.
Monday, February 18th, 2019 AT 4:03 PM (Merged)
  • 31,938 POSTS
You will have to remove the seat and see what is broken, you may be able to fit a new lever or the compleate actuator may have faild, you will just have to see which has failed.
BELLI
  • 2003 CHRYSLER SEBRING
  • 6 CYL
  • 50,000 MILES
Front passenger is stuck as far back as possible. Manual, not power, seats. How can I free it up?
Monday, February 18th, 2019 AT 4:04 PM (Merged)
  • 108,117 POSTS
Check to see if anything is stuck in the track. Also, make sure the lever is releasing the seat.
JASONSTARR2
  • 1998 CHRYSLER SEBRING
1998 Chrysler Sebring 6 cyl Front Wheel Drive Automatic
I have a '98 Chrysler Sebring LXI. The drver side seat is power and will only move up and down not forwad or backward. Could you help?
ZACKMAN
  • 4,202 POSTS
If you can gear the motor running, the guide is off the track. You have to remove the seat out of the car, and place the guide back on the track.
If you can't hear the motor, chance is the motor burned out.
