1999 Chrysler Sebring no fire
CUONTOP
  • 1999 CHRYSLER SEBRING
Electrical problem
1999 Chrysler Sebring 6 cyl Front Wheel Drive Automatic 180k miles
1999 chrysler 2.5 coupe engine starts runs few min. Then shuts down
no codes changed distributer no help
have no fire at all untill cool down then starts all over.
thanks AJ
Do you
have the same problem?
Thursday, January 7th, 2010 AT 3:41 PM
Do below immediately, to determine whether it's a fuel or spark problem, do not wait for nothing.
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Thursday, January 7th, 2010 AT 4:16 PM
Don't wait till it cools down do below immediately to catch the problem
Get a helper, disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 in away from ground have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, cap and rotor /distributor pick-up coil, ignition control module, ECM, Ignitor camshaft and crankshaft sensors- Note: If it doesn't apply disregard it
Thursday, January 7th, 2010 AT 4:18 PM
Recommended Guides
