Cracked or blown head gasket?
TABLES74
  • 2005 CHRYSLER PT CRUISER
  • 4 CYL
  • FWD
  • 47,000 MILES
I recently had to take my car to the dodge dealer and explained that the car overheated- never red lined the car came close but did not red line, they got the heads off stated that the head gasket was blown. When the car was dropped off they were told to fix the car- they called told us that we had blown a head gasket we need to replace the radiator, water pump, hoses, plugs, head gasket, thermostat housing, thermostat, also they sent the heads to a machine shop- checked for cracks, leaks resurfaced the heads, honed 2 cylinders that were damaged and some other items, I get the car back- and 3 weeks later the car starts to overheat, I called Dodge (they gave me a 12k or 1yr warranty on their service done) after we spent 2800.00 for these items- car is back in the shop now, they have called and stated that my engine is cracked- or has a hole in it or the head is warped? They are not really sure at this time. They stated this was not the case in the prior repair they completed.
There is capachino colored oil/anifreeze in the radiator when it overheated this time- has no oil in it either.
The prior time there was dark oil in the radiator with anti-freeze under (it seperated) before they did the repairs stated above. They are stating that it will be an additional 3k to repair this now because it needs an engine.
Can you tell me what you think may have happened here? They warranteed the repair work but are still charging to do the same / and more repairs now because the car is not operational.
Thank you- I just need some info on what the cause of the initial problem may have been? I think that the car may have been misdiagnosed the initial trip to the dealer, but they said they did not see a reason to check for a cracked engine block before so they never did this test.
Tuesday, December 15th, 2009 AT 4:16 PM
ERNEST CLARK
  • 1,730 POSTS
You definitely ran into a group of shysters. But first let me say this:
"Don't ever take you car to a dealership unless it's under warranty. EVER."
I know there's a lot of mechanics who'll disagree with this, but so what. You will ALWAYS get over-priced for repairs, and in some cases (like yours), you'll get screwed!
Now, even if you did have a blown head gasket at the very beginning of your car troubles, it's extrememly unlikely you'd need to have all of those components you listed repaired or replaced. (Radiator, water pump, thermostat housing)
And whatever scam they ran on you to have all of those parts replaced, if you brought your engine in because it overheated. It's there responsibility to make sure the correctly diagnosed the problem and fixed it once you paid your money. And when you rolled out of the door with your warranty in hand, any overheating issue that arises before 12K miles/1-year will be on them to remedy for free.
Finally, contact a lawyer first, then the management at the dealership. Don't argue, but inform them of your complaint, what attorney is representing you, and your intentions to file a suite against their establishment. You may even want to call your local news agency and let them know there's a shyster in town. (Let the dealership know this as well)
I'm sure the dealership will quickly see the error of their ways and agree to fix your vehicle under warranty.
Sunday, February 14th, 2010 AT 7:59 AM
GRANDMA1
  • 11 POSTS
  • 2001 CHRYSLER PT CRUISER
If my pt cruiser has a blown head gasket will blue devil gasket sealer be a good sealer to use to seal it? Thank you for your help. Linda
Wednesday, July 17th, 2019 AT 1:41 PM (Merged)
DOCFIXIT
  • 18,828 POSTS
We have had good luck with blue devil this guide will show you how to test to see if it worked.
HLACEFIELD
  • 0 POST
Thanks for this post I had this problem the BD worked great!
CLKING27
  • CHRYSLER PT CRUISER
We have a Chysler, PT Cruiser, 2001. The head gasket just blew. We had it in for an oil change and repair at an Express Oil Change. We told them the oil light was coming on, the car was leaking, and overheating. 711.00 dollars later we were back on the road. A couple of days later, the head gasket blew. What might have caused this type of major repair. The car has just over 89100 miles on it.
BACKYARDMECHANIC
  • 337 POSTS
Overheating the car is the typical way to blow a head gasket. It can also wear of time, but since you said you overheated the car then it's a good bet that is what did it. What did they charge $700 plus dollars for. Did they make repairs before the head gasket went.
PRCHSKE
  • 2004 CHRYSLER PT CRUISER
  • 4 CYL
  • 53,800 MILES
I have a 2004 PT Cruiser that has an bad head gasket and is leaking oil. I wanted to know if $1163 was a good price to repair the head gasket. I was also told the rear seal is bad too and needs to be replaced. I was quoted $563 to replace the rear seal. Just wondering if these on decent price quotes.
BLUELIGHTNIN6
  • 16,542 POSTS
Seems a little overpriced on BOTH quotes to me...
Below is an average estimate for having both the head gasket AND the rear seal replaced on your Cruiser..
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_1484.jpg
Wednesday, July 17th, 2019 AT 1:42 PM (Merged)
KINKIE321
  • 2003 CHRYSLER PT CRUISER
2003 Chrysler PT Cruiser
blew a head gasket and need to know what the torque is on the bolts.
2CARPRO JACK
  • 11,533 POSTS
2.4 DOHC
step1-25 ft lbs
step2-50 ft lbs
step3-50 ft lbs
step4- Tighten an additional 1/4 turn
tightening sequence
https://www.2carpros.com/forum/automotive_pictures/1639_pt_1.jpg
