2001 Chrysler PT Cruiser Dash Panel "Brake Light"
GREGOJD
  • 2001 CHRYSLER PT CRUISER
Electrical problem
2001 Chrysler PT Cruiser 4 cyl Two Wheel Drive Automatic 44K miles
My fathers PT Dash Panel "Brake Light" stays on all the time. I have checked the obvious, brake fluid level, reservoir fluid level switch, and the parking brake switch. I don't know what else to look for.
I have done the three on/offs of the ignition switch but no error codes pop up.
The one other that does have a problem is the the ABS service light is on and have been told I need a new control module. Could these be tied in together?
Thanks for your input.
Do you
have the same problem?
Saturday, July 11th, 2009 AT 11:39 AM
  • EXPERT
They are related. The module will set both lights.
Friday, July 17th, 2009 AT 11:58 PM
Recommended Guides
