94 Caravan 3.3l waterpump mount leak
JACK42
  • 1994 CHRYSLER
I have recently replaced my waterpump and I am still seeing coolant loss when the motor is hot. Mechanic says coolant leak is from corroded connection from waterpump to block. He says this could be a 5 hour repair do to timing chain removal. The motor is is great shape still, good compression in all cylinders. Is this repair acurate or should I see another mechanic.
Do you
have the same problem?
Friday, January 27th, 2006 AT 5:45 PM
JACK42
A second opinion never hurt
Recommended Guides
