1989 Chrysler New Yorker
TNOWAK
  • 1989 CHRYSLER NEW YORKER
The cruse control switch, has (2) screws that attach this to the main swith body in the stearing column. The t shaped bracket on the cruise control switch has broken of both ears, that the screws go thru. I have ordered a new cruise control switch, but I am unsure how to remove the main turn signal arm (turn signal arm also has wiper control's knob at the end of it) from the main switch body. The cruise control switch is hollow and the turn signal arm runs thru it.
Do you
have the same problem?
Monday, August 20th, 2007 AT 11:30 AM
TNOWAK
Never mind, figured it out myself
Tuesday, August 21st, 2007 AT 6:33 AM
Recommended Guides
