1995 Chrysler Le Baron Rough Idle
STANTINO
  • 1995 CHRYSLER LE BARON
  • 6 CYL
  • FWD
  • 110,000 MILES
My car has a rough idle problem. Particularly when you come to a stop, it may stall or the idle drops to 500rpm and then hovers between 650 and 850rpms. I have replaced spark plugs, air filter, rotor, distributer cap, plug wires, ran 3 tanks of gas with injector fluid and looked for obvious vacum leeks. The engine has good acceleration. What else could it be?
Do you
have the same problem?
Friday, November 7th, 2008 AT 9:54 AM
  • EXPERT
Has the check engine light ever come on?
Tuesday, March 17th, 2009 AT 10:41 AM
Recommended Guides
