1993 Chrysler Le Baron Starter runs when battery is hooked
CLIF TINKHAM
  • 1993 CHRYSLER LE BARON
  • 6 CYL
  • FWD
  • 261,000 MILES
Tim said to try the neutral safety switch. Unhooking it did nothing. Any other ideas? Is there a relay that could be stuck in closed position? The starter is new and has been rechecked by the parts store. New ignition switch also installed. No help.
Do you
have the same problem?
Thursday, March 27th, 2008 AT 9:35 PM
BMRFIXIT
  • EXPERT
Check starter relay at the fender
Thursday, March 27th, 2008 AT 10:34 PM
Recommended Guides
