1999 Chrysler Concorde blue smoke
OBXAUTOMEDIC
  • 3,711 POSTS
Yes, that is correct.
With the O2 sensors you have one in each Exhaust Manifold, then depending on the system set up, single or dual exhaust will depend on the other sensor(s).
Wednesday, August 26th, 2009 AT 3:46 PM
COOK2005
  • 31 POSTS
I got the check engine light again after my computer was reset. Since than I have driven 400 miles. Today I got the P0153 code.
I have a Chrysler Concorde 2.7L, 1999.
What is wrong with my car and how can I fix it?
-I was told it could be misfire (my engine was tuned up 2000-3000 miles ago with new double platinum spark plugs)
-I was told it could be bad o2 sensor or bad wires to o2 sensor
-I was told it could be fuel pump/ pressure problem
-I was told it could be leak on air intake system (I changed air filter 1000 miles ago to Fram air filter)
-I was told it could be leak on exhaust fume system.
So I really wonder what is wrong?
What do you think?
Saturday, September 5th, 2009 AT 6:29 PM
OBXAUTOMEDIC
  • 3,711 POSTS
Hello Again,
Sorry for delay in getting back with you haven't been on do to work and personal problems.
Anyway here is the code def.
P0153 Oxygen Sensor Circuit Slow Response (Bank 2 Sensor 1) this sensor should be the on ein the exhaust manifold on the back or firewall side.
Since that is the only code you got then most likely it is the O2 Sensor. I would change it and then clear codes again.
In my experience with an O2 sensor code if something else is possibly causing the code you will get more than one code. Especially in newer vehicle 98/99 and up.
Wednesday, September 9th, 2009 AT 10:52 PM
COOK2005
  • 31 POSTS
No problem because of your later reply. I understand that you are not next to your computer 24/7.
Well if I am not mistaken I got o2 sensor malfunction and this sensor is located after cat thus it is located under the car. I cannot change that without help so I need to go to mechanic who will not change it unless he can read out the code with his computer for 70$ So altogether I will pay like 200$ (o2 sensor 80$ code reading 70$, labor 50$) damn.
For how long can I drive with bad o2 sensor? My oil change is due at 14th of October. Can it last till then?
My other question is that can I go to limp mode due to o2 sensor failure?
Thanks!
Friday, September 11th, 2009 AT 10:50 AM
OBXAUTOMEDIC
  • 3,711 POSTS
Well, with the code you posted it indicates the one in the Exhaust Manifold not the one after the cat.
Your vehicle has either 3 or 4 O2 sensors and there location should be as follows.
One in each exhaust manifold then one in front of cat and then one behind cat.
As far as driving, if driven to long with faulty sensor can cause cat to go bad. And cause bigger problems.
A bad or faulty O2 Sensor will not cause your vehicle to enter Limp Mode.
I have known people who have driven the vehicles with a bad O2 sensor for up too a year with no problems except for the reduced gas milage.
Friday, September 11th, 2009 AT 9:34 PM
COOK2005
  • 31 POSTS
Okay so my bad/worn o2 sensor is located on the side of the engine not under the car thus it is before cat.
You said if I drove too long with faulty o2 sensor my cat would go wrong. What did you mean under too long? 1000 miles or less or more?
In a month I drive around 500-600 miles.
Please confirm my theory if it is true: My o2 sensor is wearing out because when my computer was reset I needed several hundred miles before the check engine light would have come back. Therefore the o2 sensor is not totally bad just worn. So I think if I go to my mechanic to change it on 14th of October when my oil change is due I would be fine and I would not cause problem to any other parts of the car. Is that right theory?
Thanks!
Saturday, September 12th, 2009 AT 8:39 AM
OBXAUTOMEDIC
  • 3,711 POSTS
Ok, I cannot honestly say how many miles you could safely drive your vehicle without changing the O2 Sensor. Each Vehicle is different and it will depend on many things one being what signals the computer is getting and then the computer telling the vehicle to give more gas or give less gas. The more it tell to give gas the more unburnt gas goes through the exhaust and the unburnt gas is what will inturn damage and cause the Cat to go bad.
If you plan on waiting till your oil change I would highly reccomend keeping an eye on you gas milage and locate the area were the cat is and keep a feel for heat in that area of the floor board. And if it starts getting hotter than normal then at that point your cat is starting to fail. And if you happen to look at it and it is cherry red you can be sure the cat is history and you may have cause some engine damage from the excessive heat.
Saturday, September 12th, 2009 AT 9:55 PM
COOK2005
  • 31 POSTS
Well it did last 200 miles and my Check Engine light came back. I did not get read out the code but I guess I would get the same o2 sensor problem code. I will go to my mechanic Monday to get my oil changed and he wants to hook up his computer to my car to see what is wrong. He said AutoZone code readers were not precise and I may have other problem with o2 sensor code such as vacuum leak. Do you think so?
I would like to ask two things.
What oil do you recommend me to use to fill after. I got Mobil from my mechanic with BG RF-7 oil treatment. I need around 1 quart refill /1670 miles. Before BG products (quick clean and RF-7) it was 1 quart/900 miles. So I use Valvoline premium conventional as refill since mobil is also conventional not synthetic or blend. 10W30 what I use. I was told quaker, penzoil, tech (walmart stuff) were not good for my engine type. So what do you think I should use to refill when I am running low on oil?
My other question is gas related. I need regular 87. I noticed that not all of the gas stations have 87. They have 86 as regular. I started using Shell regular (2.23$/gallon here in TX) that is slightly more expensive but it is just 86. I noticed better performance and I was told Shell gas had more engine/fuel system cleaning molecules than other gas. Does that 1 octaine difference count and is Shell really better than FINA or Phillips 66?
Thanks!
Wednesday, October 7th, 2009 AT 11:24 PM
OBXAUTOMEDIC
  • 3,711 POSTS
Hi Kyle,
With the O2 sensor, yes there could be other underlying problems and a vacuum leak could be one, however, usually with that year you would also get a code that would indicate a vacuum or emmission leak.
Now if you have an Exhaust leak it could cause the O2 sensor to miss read and set a code and not show or produce a code.
With the Oil I would continue using the Valvoline premium conventional or the Mobil 10w30. As long as it is helping with lowering the oil consumption.
With the Octane here is something to try and see how the vehicle does. On your next fill up use the lowest octane but get an Octane Booster and put in prior to filling up. Also most newer vehicles from 97/98 on up seem to run and get better gas milage on higher octane gas. I know our 03 Chevy Venture gets about 3 -5 more miles a gallon on the highest octane.
As far as which brand is better well honestly I don't know, It seems to me that they are all claiming to have better cleaners and will booster your milage and lengthen your engine life. So, I cannot honesly recommend one.
Mark Shreaves
Thursday, October 8th, 2009 AT 8:36 AM
COOK2005
  • 31 POSTS
HI,
So I brought to my car to service to my mechanic. I paid 311$. Since I'm a student that was expensive but I need to have a working car. (70$ computer scan, 111$ o2 sensor, 14.95$ inspection, oil change+engine clean+oil treatment)
After the computer scan I was told I had Transmission range selector error code in the memory (705 and 133) but my transmission was tested and the problem did not come up. I was told that I had had that code because my battery must have died ( it is true ) and since than it was stored.
Anyway I would like to ask you opinion about several things that I was told. This car shop has two certified Chrysler mechanics. According to their policy just they can repair my Chrysler. So I asked them about the condition of my car and engine (blow-by). They said apart from the blow-by it seemed to be fine!They said I had low compression on 2 cylinders because:
1, worn piston rings (valve steams less likely)
2, blown gasket because I have low compression on two adjacent cylinders. However my engine never overheated so I think we can disregard this option.
These are the most possible problems. They told me I had around 10.000-12.000 miles (it was rough estimate) in the car before the engine would fail. At this moment the engine works well just I got blow by that I can see when I start going from red light. It has some engine noise when idle but I was told that was normal. It has ample power and can reach 115-120 MPH without problem.
A, So I do not feel the issue but I just would like to know is there a symptom in driving performance, engine noise, etc that warns me that due to worn piston rings the engine is about to die?
B, I also was told that I should not drive on high rpm and that could help to prolong the life on my engine in this condition. Do you think that would help?
C, Do you think 10.000-12.000 miles estimate is roughly correct?
Thanks!
Friday, October 16th, 2009 AT 6:08 PM
OBXAUTOMEDIC
  • 3,711 POSTS
Ok, as I stated in the beginning they can determine if it is the Rings or the Valves by doing a Wet Compression Test. And if the test shows an increase in compression then yes it is the rings.
Answer A - The only indication will be the Increasing of Exhaust Smoke and you will develope a rough running engine. But engine shouldn't just die.
Answer B - Honestly I don't think it will matter. If it is the rings then when they decide they have had enough there going to fail no matter what. And same goes if it is the Valves.
Answer C - Honestly, I don't think you can give an accurate guestimate on how long it will last. It could last that long or longer or could fail in next month or so.
Sunday, October 18th, 2009 AT 2:39 PM
COOK2005
  • 31 POSTS
Thank you for your answers and opinion. There would be one more thing.
I went to the Chrysler dealership and asked the manager to let me speak with their mechanics. They said to my problem that thicker oil could significantly reduce blow-by. I use 10-30W. What do you think I should use as thicker oil? Also I believe thicker oil would kill my oil pump or might kill other important elements but according to Chrysler's mechanics old Chrysler cars should change to thicker oil than what is recommended.
What do you think?
Thank you for your help! I am grateful for it!
-K-
Sunday, October 18th, 2009 AT 9:36 PM
OBXAUTOMEDIC
  • 3,711 POSTS
Well I totally Disagree.
First off most vehicles that start using or getting blow-by will start using a heaver oil than recommended and it won't hurt a thing. The only thing I would suggest is that if you live in a cold climate that you get a heated dip stick to keep oil warm. The reason is that the thicker oil will take longer to circulate when it is cold.
As far as what to use I would start with a 10w40 and see how it does. Usually it will help quite a bit.
Tuesday, October 20th, 2009 AT 7:38 PM
COOK2005
  • 31 POSTS
I have a strange problem in the last couple of weeks. So I accelerate from 0 to 55mph or 50mph and when I reach the 40-42 mph my rev falls back 500-600 to 2500 from 3000 and soon jumps up back. The real strange thing is my car keep accelerating constantly so it is not like engine stall. And later around 52-53 mph the transmission goes to 4th.
Other than this I do not notice any change on my car.
Do you know what could cause this problem? Why is this magic number 40-42 or 43 mph?
THANKS!
Monday, December 7th, 2009 AT 5:15 PM
OBXAUTOMEDIC
  • 3,711 POSTS
Sounds like the tranny slipping. When was last tranny service? Take a look at the fluid the color should be reddish or some people say pinkish. Also smell it does it smell burnt. If looks brown/black and/or smells burnt have tranny serviced. A filter and fluid change should take care of the problem. Also is engine light on?
Monday, December 7th, 2009 AT 9:56 PM
COOK2005
  • 31 POSTS
Yes I agree it is transmission slipping. I read a lot on the Internet and checked youtube for videos and my symptom is similar but in my case it is very hard to notice but I know my car so I can notice any unusual noise.
I checked my transmission fluid and it is reddish, light brownish but comparing to my engine oil it is definitely reddish pinkish. In terms of smell well it is not nice but not burnt at all thus color and smell seemed okay.
I do not know when was the tranny serviced. I bought this car as a used and on the records I did not find tranny service. I can imagine that it never was serviced. If it is true I heard that I should never change the fluid because new fluid can mess it up.
Also I do not have any warning lights on.
So what do you think the problem is?
-Solenoid?
-Sensor?
-Clutch?
-Fluid and filter? (This is your guess)
More importantly how serious this problem is? I should get it fixed asap or it can wait till January when my oil change is due? Have you used Lucas Transmission fix?
Thanks for your help!
Tuesday, December 8th, 2009 AT 12:01 AM
OBXAUTOMEDIC
  • 3,711 POSTS
Well, as far as never changing tranny fluid because it will mess it up is NOT true. It will damage the tranny if fluid is cause of problem.
Since your vehicle is a 99 if it were a sensor or selenoid it would turn your engine light on.
So the possible causes without testing could be.
Broken down tranny fluid with clogged filter.
Worn Clutches.
Weak pump.
Or
Torque converter going bad.
The Cheapest this to try first would be the tranny fluid and filter change.
If doesn't fix then would need to take to tranny shop for pressure testing.
Wednesday, December 9th, 2009 AT 8:45 AM
COOK2005
  • 31 POSTS
I went to another car shop where they did free diagnostic and test on my car as well as my transmission. They did not find any problem! But I still experience the rpm drop between 3rd and 4th gear. Not right before 4th though. Like 40-45mph and rpm drops from 3000 to 2500 and 55-60 mph car goes to 4th.
I do not have any error code. I think the most probable is slipping clutch. I checked the trans. Fluid it was fine. In fact the shop did 168 point inspection + test and I was told the S-belt is worn but trans. Was fine.
Anyway, I'd like to ask that which (used) car would you suggest me to buy if I needed to buy another:
-2008 Chrysler Sebring (3.5 L)
-2008 Hyundai Sonata (3.3 L)
I like Chrysler style (similar to Mercedes from front) but I am little bit concerned due to lot of horror stories in terms of reliability. Hyundai looks nice but it has not too comfortable seats and the reputation of Hyundai is not that good although it's rising.
Saturday, December 19th, 2009 AT 10:48 PM
OBXAUTOMEDIC
  • 3,711 POSTS
Hi Kyle,
If that is the only time you notice the drop in rpm's, and there is no other time then the problem could be a Shift Selenoid or the Torque Converter. And you would need to take to a tranny shop for proper diagnosis. If it was a clutch you should feel it frequently at speeds above 45.
As far as which vehicle to purchase, the only thing I can suggest is when you go to test drive and all if possible take to someone to have it checked out and also request a Car Fax Report, if they don't get one for you take your business elsewhere. Also, get in writing what there warrantee covers and for how long. And if after you purchase the vehicle make sure that if you have any problems with the vehicle you write down the problem (date and time) call the place you purchased it from set a appointment for check. Make sure they do paperwork so there is proof of problem and make sure you get any and all paperwork they have on the problem/diagnosis.
I say the above cause my oldest daughter purchased a car without me checking it out. And she got ripped
Thursday, December 24th, 2009 AT 12:18 PM
COOK2005
  • 31 POSTS
First of all HAPPY NEW YEAR!
I am sorry that your daughter was screwed with her vehicle. Yes I want to do the paper work due course and due diligence. I have learnt a lot about cars so I am much confident now.
I went to a 400 miles trip and my car went well. 24.7 MPG average mixed driving. I also noticed that the transmission "problem" does not occur when the engine is cold in the morning. Strange.
So you think the problem is likely to be Shift Selenoid or the Torque Converter. How serious these problems are? Also how much would it cost to fix them roughly?
Another question would be that can I top of my motor oil with synthetic blend oil? I have conventional mobil from the shop but to top off I though I could use synthetic blend high mileage oil because it could treat the seals better. It is already a mix of conventional and synthetic so I guess it cannot hurt but I just want to make sure. Of course it is 10-30W also! (Valvoline Maxlife)
Thanks!
Kyle
Friday, January 1st, 2010 AT 12:33 PM
