1996 Chrysler Concorde A/C+heat control dosnot work not fus
JACK5
  • 1996 CHRYSLER CONCORDE
  • 6 CYL
  • FWD
  • 128,454 MILES
Put in new control still dosnot work
Do you
have the same problem?
Wednesday, August 20th, 2008 AT 2:16 PM
  • EXPERT
Hi:
Do you mean the blower motor doesn't work? If not and you replaced the switch, there are a couple other things to check. First, check the blower motor resistor. If you have power there, next check the motor itself. If you have power there and the motor doesn't work, the motor needs replaced.
Let me know if this is what you needed.
Tuesday, October 21st, 2008 AT 7:25 AM
Recommended Guides
