1999 Chrysler Cirrus CAR NOT GETTING ANY FIRE
CORNELIUS1982
  • 1999 CHRYSLER CIRRUS
Engine Cooling problem
1999 Chrysler Cirrus 6 cyl Front Wheel Drive
THE THE ENGINE IS TURNING OVER BUT NOT STARTING WHAT IS IT
Do you
have the same problem?
Sunday, January 10th, 2010 AT 12:27 PM
JDL
  • EXPERT
Welcome to the forum, have a helper crank the engine while you check for spark at the plugs. You can pull a plug boot, stick known good spark plug or spark tester in the boot. Ground the plug or tester to metal part of engine, watch for spark. If spark everywhere, use a fuel pressure gage and check fuel pressure. Some of the national brand autostores used to loan fuel pressure gages? You can call and ask
Sunday, January 10th, 2010 AT 1:12 PM
Recommended Guides
