2007 Chrysler Aspen check engine light
DAVES1985
  • 2007 CHRYSLER ASPEN
  • V8
  • AWD
  • 47,500 MILES
I have had it the to dealer while under warranty, they day they fixed it and still the light comes back, they changed the #5 cylinder spark plugs! The code was #5 cylinder misfire ! The light came back on numerous ocassions after the warranty runs out So I Changed all the plugs (16)! I got a light 2 weeks after, Code ~ #4 misfire
1 week later Code~ #5 misfire what is going on Please
Do you
have the same problem?
Monday, July 27th, 2009 AT 10:30 PM
  • EXPERT
Has the check engine light come on? If so, I need to know what code came up. Also, have they checked the crank sensor and made sure the wiring harness to the PCM is tight?
Tuesday, December 8th, 2009 AT 10:12 AM
