2005 Chrysler 300 power window
APSCKD
  • 2005 CHRYSLER 300
Electrical problem
2005 Chrysler 300 6 cyl Two Wheel Drive Automatic
my power window on the driverside and passenger side does not work I just replaced the power window module and still no power the passenger side works fine using the passenger side control (also my power mirror stopped working at the same time)
Do you
have the same problem?
Tuesday, May 26th, 2009 AT 7:05 PM
IMPALASS
  • EXPERT
Hello -
To better assist you is your model just a 300, or is it the 300C, Limited, SRT-8 or Touring? Also I know it is a 6cyl, can you give me the engine size in liter please.
Also, it looks like you can check for DTC for your windows. This may save us some time. Please go to Auto Zone (AZ) or O'Reilly's (OR) and for FREE they can pull the codes to the car. Most important: Once they check your codes, if they find something and you don't get it fixed and need to get back with us, please make sure you tell us exactly what the code was, number and all. Example, if the code was E0568 O2 Sensor bad. Then make sure you give us all of that.
Tuesday, May 26th, 2009 AT 8:22 PM
IMPALASS
  • EXPERT
Hello -
I haven't heard back from you. Maybe your car is fixed now. I am not sure of your exact model but for the 300 model you may have a recall.
The dealer may fix this for free. Please contact the dealer service department, give them the VIN number of your car and have them check on this to see if it applies to you.
POWER TRAIN:AUTOMATIC TRANSMISSION
NHTSA RECALL BULLETIN
Reference Number(s): 05V460000
Related Ref Number(s): 05V460000
ARTICLE BEGINNING
VEHICLE DESCRIPTION
Model(s): 2005 CHRYSLER 300
2005 DODGE DAKOTA
2005 DODGE DURANGO
2005 DODGE MAGNUM
2005 JEEP LIBERTY
2005 JEEP WRANGLER
2006 CHRYSLER 300
2006 DODGE CHARGER
2006 DODGE DURANGO
2006 DODGE MAGNUM
2006 JEEP LIBERTY 4X4
2006 JEEP WRANGLER
Campaign No: 05V460000
Number of Affected Vehicles: 256409
Beginning Date of Manufacture: 2004 JUL
Ending Date of Manufacture: 2005 OCT
SYSTEM
DESCRIPTION OF DEFECT
ON CERTAIN PICKUP TRUCKS, SPORT UTILITY AND PASSENGER VEHICLES EQUIPPED WITH 42RLE AUTOMATIC TRANSMISSIONS, THE CUP PLUG THAT RETAINS THE PARK PAWL ANCHOR SHAFT MAY BE IMPROPERLY INSTALLED. IF THE SHAFT MOVES OUT OF POSITION, THE VEHICLE MAY NOT BE ABLE TO ACHIEVE 'PARK' POSITION.
CONSEQUENCE OF DEFECT
IF THIS OCCURS AND THE PARKING BRAKE IS NOT APPLIED, THE VEHICLE MAY ROLL AWAY AND CAUSE A CRASH WITHOUT WARNING.
CORRECTIVE ACTION
DEALERS WILL INSPECT THE TRANSMISSIONS AND INSTALL A BRACKET TO ENSURE THE PARK PAWL ANCHOR SHAFT IS RETAINED IN THE PROPER POSITION. THE RECALL BEGAN ON NOVEMBER 28, 2005. OWNERS MAY CONTACT DAIMLERCHRYSLER AT 1-800-853-1403.
ADDITIONAL INFORMATION
The National Highway Traffic Safety Administration operates Monday through Friday from 8:00 AM to 4:00 PM, Eastern Time. For more information call (800) 424-9393 or (202) 366-0123. For the hearing impaired, call (800) 424-9153.
Tuesday, June 2nd, 2009 AT 9:06 PM
Recommended Guides
