Won't shift
E JURGENS
  • 2004 CHEVROLET VENTURE
  • 6 CYL
  • FWD
  • 11,000 MILES
The transmission will not shift out of first gear It only stays in the gear that it is in when you put it in Drive and my speedometer is not working?
Sunday, December 27th, 2009 AT 3:14 PM
  • 108,128 POSTS
It sounds like the VSS has gone bad here is a diagrams below to show you the location so you can change it out. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Sunday, January 3rd, 2010 AT 8:46 PM
REDDOGZ06
Thanks for this post I had this problem and the VSS fixed it. I love this site.
Saturday, January 26th, 2019 AT 4:27 PM
JHARDIN1919
  • 1999 CHEVROLET VENTURE
  • 6 CYL
  • FWD
  • 125,000 MILES
Transmission will not shift out of first checked the fluid level it is ok, reverse is ok.
Saturday, January 26th, 2019 AT 4:28 PM (Merged)
JHARDIN1919
Sorry (fluid level)
OBXAUTOMEDIC
  • 3,711 POSTS
Is the check engine light on? If so will need to have codes pulled.
Could be the In-Put and/or Turbine Speed Sensors or possible the TCM (Transmission Control Module)
JOSHUAGANN3915
  • 2003 CHEVROLET VENTURE
  • 3.4L
  • V6
  • FWD
  • 190,000 MILES
I start the van on cold morning and let it run for 10 minutes to warm and the transmission won't shift into gear. What is the problem?
HMAC300
  • 48,601 POSTS
Check fluid level if you can then have a trans guy scan it. It may be time for a rebuild if fluid is dark brown or black
JOSHUAGANN3915
Thank you I checked the fluid. It's the right color and full
HMAC300
  • 48,601 POSTS
Then have a trans guy look at it as it can be an internal problem
TERRYWAGNER
  • 6 CYL
  • FWD
  • 165,000 MILES
Computer codes show tcs stuck on -- if I have to change out the solenoid I hear I have to remove the left front axle to gain access to tranny -- can I change the solenoid myself or does it require special tools
BLUELIGHTNIN6
  • 16,542 POSTS
First may want to check the tranny fluid level and the cooler lines from the tranny to the radiator, make sure lines are not pinched, plugged or twisted. These conditions will also set that trouble code.
MOHAMMED SALIM
  • 5 POSTS
  • 2001 CHEVROLET VENTURE
  • 180,000 MILES
Respected Sir, My car have some problem which iam unabel to understand the problem is at the time of car shifting gare no.2 car vibrate, then shift gare when the speed is slow the engine stop, waiting for your suggestion.
Thanking you,
your's faithfully mohammed salim
MOHAMMED SALIM
  • 5 POSTS
Respected sir its auto transmission sorry for that eagrly waiting for your reply sir,
thanking you
  • 108,128 POSTS
Has the check engine light come on? Is the transmission fluids clean and full?
THEOZ76
  • 2000 CHEVROLET VENTURE
  • 3.4L
  • 6 CYL
  • FWD
  • 165,000 MILES
Will not shift automatically will shift manually only
HMAC300
  • 48,601 POSTS
Have a trans guy look at this and scan may be a valve body problem or wiring issue.
FREEMBA
  • 1,152 POSTS
Check your TCC fuse (10A) in the underhood fuse box above the battery (passenger side).
2CP-ARCHIVES
  • 4,542 POSTS
  • 157,429 MILES
My 1999 chevy venture sarts then when I shift to drive it shuts down
  • 52,797 POSTS
Is there a check engine light? If so, we need the code.
It could be an idle control motor failure, vacuum leak or something with the trans.
