1999 Chevy Venture Coolant leak?
BMBR34
  • 1999 CHEVROLET VENTURE
  • 6 CYL
  • 160,000 MILES
I have a coolant leak off a hose on the backside top of the engine right next too the transmission fluid check stick. It seems to be heavily adgitated when the heat is on in the vehicle and blows quite a bit of smoke. The attached pic is a picture of the hose that is leaking. My question is where does that hose run too/from and how easy would it be to replace
http://www.2carpros.com/forum/automotive_pictures/577958_Car_002_1.jpg
Do you
have the same problem?
Wednesday, September 29th, 2010 AT 12:16 PM
BUDDYCRAIGG
  • EXPERT
I'm pretty sure that is your thermostat housing
Wednesday, September 29th, 2010 AT 3:00 PM
Recommended Guides
