1999 Chevy Malibu NO HEAT INSIDE CAR
ELDRIC
  • 1999 CHEVROLET TRUCK
JUST STARTED LAST WEEK. VERY LITTLE HEAT COMING IN THROUGH THE VENT. HAD THERMOSTAT CHECKED. WORKING FINE. CAP STUCK ON RESERVOIR, BUT DON'T THINK THAT HAS ANYTHING TO DO WITH IT. RADIATOR IS WORKING PROPERLY. AM THINKING IT'S EITHER THE HEATER CORE, OR AN ELECTRICAL PROBLEM. DON'T KNOW. PLEASE HELP.
Do you
have the same problem?
Tuesday, January 10th, 2006 AT 4:14 PM
JACK42
See if hot-cold door is working properly. Also see if heater hoses are hot while engine is warmed up, be careful
Tuesday, January 10th, 2006 AT 5:35 PM
PVITULLI
Here is a quick way to check if its the heater core or not.
First warm up the car and turn on the heat.
Then feel the 2 hoses going through the firewall to the heater hose.
If one is hot and the other is not.
You have a clogged heater core.
Also check your fluid level.
Saturday, January 14th, 2006 AT 5:50 PM
Recommended Guides
