1996 Chevy Truck Chrome wheels stuck
49RIVIERA
  • 1996 CHEVROLET TRUCK
Tires and Wheels problem
1996 Chevy Truck 6 cyl Two Wheel Drive Manual
I'm trying to get the rear wheels of a Chevy Truck.
The Chrome plated steel wheels are stuck to the break drums, tried the pounding routine. Any suggestions?
My email is tcarstens@wi. Rr. Com
not sure if you have my correct email in your records.
Do you
have the same problem?
Sunday, June 13th, 2010 AT 4:04 PM
OBXAUTOMEDIC
  • EXPERT
They are of course rusted on, when you pounded on them did you dofrom front or back or both?
Have you sprayed them down good with WD40 or similar?
Have you tried using a wire brush around the center part that the wheel goes on to remove as much rust as possible.
After spraying and wire brushing try pounding them off usually works better from back side and hitting different areas.
Sunday, June 13th, 2010 AT 9:01 PM
Recommended Guides
