1996 Chevy starting issues
WING235
  • 1996 CHEVROLET TRUCK
Just recently my 1996 chevy k/1500 5.7 vortec started doing this wierd thing when im try to start it. When you turn the key all the way forward to start it trys to fire and run but when you let off it keeps trying to start and fire and when you turn the key all the way off it stops trying to fire and just turns the motor over. The only way I can get it to stop is if I turn the switch between start and off alot. It doesn't run at all. It has been setting for a week and has never done this before.
Do you
have the same problem?
Tuesday, February 13th, 2007 AT 10:31 PM
Start with the Igniton Switch sounds like it
Wednesday, February 14th, 2007 AT 4:02 AM
Recommended Guides
