Transfer case not working
SLUDOG76
  • 1998 CHEVROLET TRUCK
  • V8
  • 4WD
I have a '98 Z71 with a NV243 transfer case, all of the lights on the selector switch are lit up, the Tcase is in 2wd, but I can not select another gear. Is this a common problem, I was told it was the selector motor, but do not want to replace it if it is a simpler fix. Any thoughts?
Wednesday, February 16th, 2011 AT 12:44 AM
  • 108,133 POSTS
Check the wiring harness at the actuator for breaks or damage. Also, the check the plug.
Thursday, April 7th, 2011 AT 4:12 PM
TRIPLXXX
  • 5 POSTS
Drive Train Axles Bearings problem
1998 Chevy Truck V8 Four Wheel Drive Automatic
the four wheel drive won't shift on the go. It has the push button on the dash for 4 lo, 4 hi and 2.
The only way to get it into 4 wheel is to come to a complete stop put it in neutral push 4 lo first you can hear it engage right away then go to 4 hi which you can also hear right away. To go back to 2 wh drive you have to again come to a complete stop put it in neutral and push the 2 wh drive button. It then turns the 2 wh button solid for a few seconds then the light gos out and the 4 hi button starts blinking and never stops.
So far I have replaced 2 switches on the transfercase and one in the dash. None of them have made a difference.
Any ideas?
Thanks,
Jeremy
Saturday, May 6th, 2017 AT 8:52 PM (Merged)
FACTORYJACK
  • 4,159 POSTS
Coming to a complete stop and being in neutral would be the norm any time you're going in, or out of 4 lo. Here is the description of a range shift:
Range Shifts
The range shifts are the shifts between the HI and the LO ranges.
"Â 2HI to 4LO
"Â 4HI to 4LO
"Â 4LO to 4HI
"Â 4LO to 2HI
A range shift can only be made with the automatic transmission in neutral or with the manual transmission clutch fully depressed. The shift occurs when the vehicle speed is below three miles per hour.
Whenever a shift into 4LO is initiated, the 4LO shift select button blinks. The 4LO shift select button will continue to blink until the shift is completed mechanically or until 30 seconds elapses. The 4LO shift select button must be on and not blinking prior to shifting the transmission into gear or releasing the clutch pedal.
If a range shift is initiated when the transmission is engaged or the vehicle speed is above 3 mph, the 4LO shift select button will blink for 30 seconds and no range shift actually occurs, the TCCM will default and position the transfer case into 4HI.
Here is the description of a mode shift:
Mode Shifts
The mode shifts are shifts from 2HI to 4HI and 4HI to 2HI. A mode shift can be accomplished in any gear position and at any vehicle speed. If the system is in 2HI, the driver can shift into 4HI merely by pressing the 4HI shift select button. The 4HI button will blink status whenever a 2HI or 4HI shift is initiated and will continue to blink until the TCCM completes the shift. After the shift into 4HI is accomplished, the 4HI status lamp remains lit to indicate that the system is in 4HI.
There is a difference between when the TCCM sends voltage signals in order to engage a four wheel drive shift and when the vehicle is truly in four wheel drive. The transfer case can be shifted into 4HI and the front axle may not be engaged.
The driver can shift from 4HI back to 2HI by pressing the 2HI shift select button. The 2HI shift select button blinks until the shift to 2HI is complete. The 2HI shift select button will remain on once the shift is mechanically complete.
Does this transfer case select switch have an auto 4WD position, or is it just straight selectable.
Next would be to check for codes. On a straight selectable o-auto case, you ground pin 13 at the data connector under the dash. I dont have an illustration of which pin that is, but the wire color is orange. The lights on the switch should flash. You are only going to have a choice of 4 codes. Here is the procedure to further clarify.
Diagnostic Trouble Code (DTC) Displaying
The transfer case shift control module is equipped with the ability to store diagnostic information, which is useful to a technician in the event of module, component or wiring failures. This information can be retrieved from the transfer case shift control module by way of flash codes, which are displayed on the three transfer case shift control switch buttons. These buttons are located on the instrument panel to the right of the steering wheel Before obtaining DTCs, perform the following transfer case control module (TCCM) Self-Test.
TCCM Self-Test
Observe the transfer case shift control switch indicators while turning the ignition switch to RUN. A properly operating system will flash all indicators and then will return to the current gear. If the system is operating normally, then proceed to Displaying Codes.
If the TCCM failed the Self-Test, then test the following circuits.
"Â Battery Positive Voltage (40 and 1640), and Ignition 3 Voltage for battery voltage
"Â Ground Circuit for ground
"Â Diagnostic enable circuit for an open or high resistance
"Â Transfer case shift control switch connector
If the above circuits are normal but the TCCM still fails the Self-Test, replace the TCCM. Refer to Transfer Case Shift Control Module Replacement.
DTC Displaying
Turn OFF the ignition for 10 seconds.
Connect PIN 13 on the data link cable (DLC) to a ground. The DLC is located in the cab under the instrument panel on the driver's side.
Turn ON the ignition, with the engine OFF.
Observe the transfer case shift control switch select buttons for flashing codes. Refer to Diagnostic Trouble Code (DTC) List.
Important: If the transfer case shift control switch buttons all blink only once and then stop, no fault codes are stored in the transfer case shift control module.
"Â When one DTC is stored in memory, that code will blink that number of times followed by a 3 second pause and then repeat.
"Â If more than one code is stored, the first code will blink, followed by a 3 second pause and then the second code will blink.
"Â This sequence will continue until PIN 13 on the DLC is no longer grounded.
"Â If the TCCM will not communicate the presence or absence of DTCs, test the above circuits in Self-Test Step 2. If the circuits are complete, then replace the TCCM. Refer to Transfer Case Shift Control Module Replacement.
TRIPLXXX
  • 5 POSTS
Is the tccm located on the left side of transfer case beside the front drive shaft?
If so it looks like there is 2 parts to it. There is the part were the plug goes and then there is a larger plate that is bolted on.
FACTORYJACK
  • 4,159 POSTS
The TCCM should be in under the dash. Near the steering column. I don't have any illustrations of it. I can give you wire colors if it will help.
TRIPLXXX
  • 5 POSTS
I talked to the dealership about a price on the TCCM. They didn't know if I was talking about the Module on the transfercase itself or if I meant the Transfer Case "Service" Control Module. Which is located under the dash left of the steering column.
I uploaded some pictures that I got from the dealership and they circled the parts on the transfer case and under the dash. Which one?
Thanks
Jeremy
FACTORYJACK
  • 4,159 POSTS
I don't know what they are describing on the transfer case itself, the only component on the case is the encoder motor. The TCCM that I am describing is under the dash near the steering column, that is for selectable FWD. In fact automatic transfer case shift control module is shown in the same place. I did not see any links to pictures.
SCOOTERLESS
  • 1997 CHEVROLET TRUCK
  • 125,000 MILES
I shift into 4 wheel drive lights are on, on the floor shifter but wheels not engaging
  • 108,133 POSTS
Check vacuum supply to front axle. If this is an electric shift 4wd, check to make sure the actuator is getting power.
STOGDOG
  • 5 POSTS
Put a socket in it.
JIM SCHOLTEN
  • V8
  • 4WD
  • 97,000 MILES
Transmission problem
1997 Chevy Truck V8 Four Wheel Drive Automatic 97000 miles
We live in Southern Utah and spend most of this part of the season driving in 4 wheel drive. I've explained to my wife SEVERAL TIMES that when she gets on roads with good traction to disengage the 4 wheel drive. She recently got on the freeway and drove 25 miles at 80 mph in 4 wheel drive. The 4 wheel drive will no longer engage. The button on the dash to engage the 4 wheel drive flashes but won't go solid green indicating its locked. The truck operates correctly in 2 wheel drive. The truck is equiped with standard auto hubs on the front axle. Can you tell me where I need to start looking? Oh I also forgot, this is all my fault as I should have reminded her
MDORCEY
Her driving in 4 shouldn't cause this problem, first turn the ignition on with the truck off and the door open and listen when pushing the button to see if the transfer case is shifting into 4 its a kind of loud click from the t-case area, if you hear that, then check into the switch in the front diff, it is on the passenger side of the front differential, I have hade that go out several times. If you don't hear the click from the tcase, then look into that solinoid, also double check that ice isn't built up around the tcase shift arms, I have also had that happen on a kinda warm i.E. Lower30s day when the roads are slushy
MACDONALD
  • 1996 CHEVROLET TRUCK
I have 1996 chevy blaser and it is a 4x4 with the manule shifter not the electrical shifter for the 4x4 function. When u ingage the 4x4 the transfure case ingages but the front end will not ingage the front difrental. Any help it much apreshated.
MERLIN2021
  • 17,250 POSTS
Any noises? If not you must have a broken fork. If yes then check the u-joint.
LORNER
Hey merlin. Where is this broken fork located? I am wondering if this is my problem with my blazer, which is stuck in four low. What do you think? :
HUCKLEBUCK911
  • 1991 CHEVROLET TRUCK
  • V8
  • 4WD
  • 150,000 MILES
1991 Chevy Truck V8 Four Wheel Drive Automatic 150000 miles
I have automatic lock-in hubs in my truck. But it will not lockin. The lights will not even come on. Its not the fuse I dont think. It might be the actuator motor
MERLIN2021
  • 17,250 POSTS
SYMPTOM TROUBLE SHOOTING FOUR WHEEL DRIVE DOES NOT ENGAGE TRANSFER CASE DIAGNOSIS FOUR WHEEL DRIVE ENGAGES BUT INDICATOR LAMP WILL NOT LIGHT FOUR WHEEL DRIVE ENGAGES BUT INDICATOR LAMP WILL NOT LIGHT 4WD INDICATOR LIGHT WON'T TURN OFF (4WD DISENGAGES PROPERLY) 4WD INDICATOR LIGHT WON'T TURN OFF (4WD DISENGAGES PROPERLY) FOUR WHEEL DRIVE WILL NOT DISENGAGE FOUR WHEEL DRIVE WILL NOT DISENGAGE JUMPS OUT OF FOUR WHEEL DRIVE POSSIBLE CAUSE: CORRECTION: Blown A/C-HTR Fuse. Replace. Faulty transfer sw. Replace. Faulty 4WD Indicator light, sw, or wiring (4WD engaging but indicator light not coming on. Repair as needed. Transfer case linkage improperly adjusted or disconnected. Adjust or repair. Faulty transfer case: Drive chain broken, range selector ring broken Repair Faulty front axle. Repair POSSIBLE CAUSE: CORRECTION: Blown bulb. Replace. A/C-HTR fuse blown. Replace. Faulty front axle sw. Replace. Faulty wiring. Repair open in wiring. POSSIBLE CAUSE: CORRECTION: Faulty front axle sw. Replace. POSSIBLE CAUSE: CORRECTION: Faulty wiring or front axle sw. (4WD disengaging but indicator light staying on). Replace or repair wiring. Transfer case linkage binding or improperly adjusted. Replace or repair. Faulty front axle shift mechanism.
CHIEFF
  • 1988 CHEVROLET TRUCK
  • V8
  • 4WD
  • 130,000 MILES
88 chevy 3500 wont go into 4 wd
SHADOW1265
  • 8 POSTS
4 wheel drive actuator on front differental may be faulty. It threads into passenger side of the pumkin. Unplug the electrical connector. Shift into 4 wheel and test connector with test light 1 side should be hot whith key on. The actuator is 1 1/4 wrench. Easy to change. If you have power change it, if no power check 4 wheel fuse in fuse box
CAPTKIRK
I can't remove the ignition key? Also truck will not go into park?
Saturday, May 6th, 2017 AT 8:53 PM (Merged)
