1990 Chevy Truck A/C not working
BILLK
  • 1990 CHEVROLET TRUCK
  • V8
  • 4WD
  • 69,000 MILES
My AC does not work. AC was converted to 134a many years ago. System is full of refrigerant. If I bypass the AC compresser cycling switch the compressor runs and it blows cold air. Before I replace the switch is there anything else I should check?
Thank you
Do you
have the same problem?
Thursday, June 25th, 2009 AT 6:28 PM
BUDDYCRAIGG
  • EXPERT
Bad switch is all
Monday, June 29th, 2009 AT 4:54 PM
Recommended Guides
