1990 Chevy Cavalier
DRACO00_29
  • 1990 CHEVROLET TRUCK
Well the car sat not running for a year and a half no money to fix. Now that I do I have replaced alternator, battery, air filter, spark plugs, ignition wires, fuel filter, oil, oil filter and the IAC gauge, cleaned the throttle body internally and the IAC body internally. But here is the problem when I coast down my drive way in nutreul and brake or not it will stall and die as soon as the angle changes. Yet it will start back up. It will even do it on a level surface. Any ideas? Also as soon as I replaced the IAC gauge the idle would go up and down irratically and pushing the gas pedal had no effect it just did what it wanted to. After about 20 min the idle fixed itself but it kinda feels rough just as it did when it started right up after changing the alt. Batt. And oil. I need help out of Ideas and this car needs to run.
Do you
have the same problem?
Tuesday, March 14th, 2006 AT 10:51 PM
RAYHUT
Try changing out you voltage regulator and or coil
Wednesday, March 15th, 2006 AT 6:23 AM
Recommended Guides
